- Thank you received: 6
an issue with static condensation and BND symbolicBFI
- Guosheng Fu
- Elite Member
7 years 2 months ago #622
by Guosheng Fu
an issue with static condensation and BND symbolicBFI was created by Guosheng Fu
Hi
I am having trouble with static condensation when a facet-BND BFI is used.
In the attached code, HDG is used to solve Poisson equation with 1 Neumann bc.
I artifically increase the stab parameter by a factor of 2 on the Neumann boundary with the following command,
a += SymbolicBFI(alpha*order**2/h*jump_u*jump_v, BND, skeleton=True)
The local solver in the static condensation implementation seems not seeing this BFI, and produce a wrong solution (comparing with condensation=False).
Guosheng
Guosheng
7 years 2 months ago #623
by schruste
Replied by schruste on topic an issue with static condensation and BND symbolicBFI
Dear Guosheng,
Static condensation of inner unknowns is only provided for (the sum of) element-based integrals, i.e. standard volume integrals or element_boundary integrals.
For skeleton-based integrals (i.e. loops over facets) the general assumptions on the couplings prohibits an element-wise static condensation.
For the specific case that you mean hear, the integrals could theoretically be added to the element-wise integrals and thus allow for static condensation. But that is not how it is implemented right now. It is treated as a "skeleton"-integral and his hence not considered during static condensation.
To fix your problem make sure to implement your integrals as element_boundary integrals.
- Guosheng Fu
- Elite Member
7 years 2 months ago #624
by Guosheng Fu
Replied by Guosheng Fu on topic an issue with static condensation and BND symbolicBFI
i see!
i will try to put everything in element boundary formulation.... it should be easy to do with the help of a facet dg p0 space.
thanks fotr the clarification
Time to create page: 0.165 seconds
