Suitesparse UMFPACK
8 years 3 months ago #73 by ddrake
Suitesparse UMFPACK was created by ddrake
Hi
I installed Suitesparse from source on my Ubuntu machine and installed it to /usr/local.
I see libumfpack.so.5.7.6 in /usr/local/lib
I set USE_UMFPACK. ON in ccmake. It configures but also sets a temporary install directory UMFPACK_DIR /home/dow/ngsuite/ngsolve-build/umfpack/install
When I try to make, I get this:
CMake Error at CMakeLists.txt:290 (find_package):
Could not find a package configuration file provided by "suitesparse" with
any of the following names:
suitesparseConfig.cmake
suitesparse-config.cmake
Add the installation prefix of "suitesparse" to CMAKE_PREFIX_PATH or set
"suitesparse_DIR" to a directory containing one of the above files. If
"suitesparse" provides a separate development package or SDK, be sure it
has been installed.
I tried setting CMAKE_PREFIX_PATH and suitesparse_DIR to /usr/local and a few other locations, but keep getting the same error. I can build Ngsolve with USE_UMFPACK OFF.
Thanks!
8 years 3 months ago #74 by matthiash
Replied by matthiash on topic Suitesparse UMFPACK
Usually, when you set USE_UMFPACK=ON, UMFPACK is built automatically and linked as static library to NGSolve. Therefore we need a temporary install directory. Linking your own version of UMFPACK is currently not supported.
Concerning the build error we had an issue with Suitesparse/UMFPACK that was resolved last week, see this commit sourceforge.net/p/ngsolve/git/ci/4790566...912d8491c75f9aa785c/
Please check out the latest master and try to build it from scratch again.
Regards,
8 years 3 months ago #76 by ddrake
Replied by ddrake on topic Suitesparse UMFPACK
Thanks, Matthias!
I will do as you suggest. Is it correct that liblapack-dev should be installed on my system first? Do you know of any additional dependencies for suitesparse that are not listed on the NGSolve installation page ?
Dow
8 years 3 months ago #77 by ddrake
I uninstalled suitesparse from my system and did a fresh install of the the current source for netgen/ngsolve. I turned on UMFPACK in ccmake and accepted the temp directory for build, but when I tried to make, I did not see suitesparse being cloned or downloaded -- I just get the same error as before.
-- Found Netgen: /home/dow/ngsuite/ngsolve-install/lib/cmake/netgen
-- Looking for include file dlfcn.h
-- Looking for include file dlfcn.h - found
-- Looking for abi::__cxa_demangle
-- Looking for abi::__cxa_demangle - found
has been installed.
-- Configuring incomplete, errors occurred!
If I turn off UMFPACK in ccmake, the build works fine.
Thanks!
Dow
8 years 3 months ago #78 by matthiash
Hi Dow,
I see, that's indeed a bug that's only triggered if you configure with ccmake/cmake-gui.
I posted a fix that should be upstream within an hour. As a workaround you can give the option when first calling cmake and avoid using ccmake, like this:
cmake -DUSE_UMFPACK=ON path_to_source_dir
Regards,
Time to create page: 0.145 seconds
