- Thank you received: 3
NumProcs and ctypes
7 years 3 months ago #617
by ddrake
NumProcs and ctypes was created by ddrake
The DPG library has some useful NumProcs written in C++ and used by pde files. I was wondering if it would be possible to bring those NumProcs into Python in the same way we can bring in spaces and elements using ctypes.CDLL.
For example, we have in 'fluxerr.cpp':
Then in a pde file:
This works, but in Python,
gives "TypeError: ngsolve.comp.NumProc: No constructor defined!"
template<typename SCAL>
class NumProcFluxError : public NumProc { ...
NumProcFluxError ( shared_ptr<PDE> apde, const Flags & flags) : NumProc(apde) {
fes = GetPDE()->GetFESpace(flags.GetStringFlag("fespace",NULL));
ext = GetPDE()->GetFESpace(flags.GetStringFlag("extensionspace",NULL));
hdivip = GetPDE()->GetBilinearForm(flags.GetStringFlag("hdivproduct",NULL));
q = GetPDE()->GetGridFunction(flags.GetStringFlag("discreteq",NULL));
Q = GetPDE()->GetGridFunction(flags.GetStringFlag("exactq",NULL));
err = GetPDE()->GetGridFunction(flags.GetStringFlag("errorsquareq",NULL));
static RegisterNumProc<NumProcFluxError<double>> npinitfluxerr("fluxerr");
Then in a pde file:
shared = "../libDPG"
numproc fluxerr calc_fluxerror_fracnorm # Calculate ||q - Q||.
-exactq=qex -discreteq=qRT -extensionspace=RT
-fespace=fs -hdivproduct=hdivipe -errorsquareq=qerrsqr
from ctypes import CDLL
libDPG = CDLL("../libDPG.so")
np = NumProc('fluxerr', exactq=qex, discreteq=qRT, extensionspace=RT,\
fespace=fs, hdivproduct=hdivipe, errorsquareq=qerrsqr)
7 years 2 months ago #669
Replied by christopher on topic NumProcs and ctypes
You would have to export the numproc to python. For some first introduction see
ngsolve.org/docu/latest/mylittlengs/1_Basic/pythonExport.html
The python export code would look something like this:
And you would have to provide a C++ constructor for the numproc with the arguments you want to call it from Python. Then you should be able to import your library and create the numproc like this:
PYBIND11_MODULE(libDPG,m) {
// import ngsolve such that python base classes are defined
py::module::import("ngsolve");
py::class_<NumProcFluxError, shared_ptr<NumProcFluxError>, NumProc>
(m, "NumProcFluxError")
.def(py::init<types of constructor arguments>())
from libDPG import *
np = NumProcFluxError(constructor arguments...)
