Div of a Curl
7 years 3 months ago #606 by ddrake
Div of a Curl was created by ddrake
I've been enjoying the updated iTutorials very much!
I noticed a small issue with the new HCurlDiv iTutorial, though...
It tries to compute the div of the curl of a grid function l in block 12, and fails like this:
Exception Traceback (most recent call last)
<ipython-input-14-3853ecb1c0ea> in <module>()
----> 1 div(uc)
~/ngsuite/ngsolve-install/lib/python3/dist-packages/ngsolve/utils.py in div(func)
84 if add:
85 return add
---> 86 raise Exception("cannot form div")
87
88
Exception: cannot form div
Just to see what would happen, I changed a line in utils.py (as below) and restarted the Jupyter kernel.
def div(func): # if func.derivname == "div": if func.derivname in ["div", "curl"]: return func.Deriv() add = func.Operator("div") if add: return add raise Exception("cannot form div")
It seemed to work:
div(uc)
<ngsolve.comp.CoefficientFunction at 0x7fd22cce68e0>
Dow
7 years 3 months ago - 7 years 3 months ago #608 by christopher
Replied by christopher on topic Div of a Curl
Hi, that line was there to show that you cannot form the div of a function in HCurl (because its not implemented either as the default operator or as an additional operator). So it raises an exception.
The function .Deriv() returns the default derivative for the finite element space the Testfunction/Trialfunction/Gridfunction is defined on. We give a function from HCurl, so
returns true and with
return func.Deriv()
you return the curl of the function not the div...
Last edit: 7 years 3 months ago by christopher.
7 years 3 months ago #611 by ddrake
Replied by ddrake on topic Div of a Curl
Hi Christopher,
Thanks for clearing up my misunderstanding on this!
Dow
7 years 3 months ago #615 by plederer
Replied by plederer on topic Div of a Curl
Hi dow!
Note however that the piecewise grad operator is exported for H(curl) function. By this you could for example implement (just for fun :D...) an H(curl) conforming dg vector laplce problem.
Thus you can easily implement the pice-wise div operator on your own.
Best, Philip
PS: I think grad(u) is actually the transpose...
Time to create page: 0.145 seconds
