Visualization settings for Magnetic field tutorial
7 years 3 months ago #599 by ddrake
I haven't ever been able to figure out the visualization settings necessary to see the magnetic field solution in this tutorial:
ngsolve.org/docu/latest/whetting_the_appetite/cmagnet.html
I scroll to zoom into the bounding box, but everything is gray or white. No pretty image like in the screen shot. I'm sure it must be something simple...
Thanks!
Dow
7 years 3 months ago - 7 years 3 months ago #600 by bernd
Hi Dow,
Using a clipping plane orthogonal to the z-axis with appropriate distance settings gives you the desired visualization.
Check the following image for all the options:
These are the things I changed in the menu
Visual
OptionValue
AutoscaleOff
Max-value6e-8
Clipping Plane Sol:Scalar Function
Scalar Function:B-field (3)
and in the menu
Clipping
OptionValue
Normal y0
Normal z-1
Distance0.008
Additional Disctance0.3
Enable clippingOn
I hope this helps!
Bernd
Last edit: 7 years 3 months ago by bernd. Reason: Properly embed image
