1-D Error Estimation and Refinement
7 years 3 months ago - 7 years 3 months ago #595 by ddrake
In adapting the Error Estimation and Refinement iTutorial to a use a 1-D mesh, I'm running into a couple of issues.
First, If I specify the 'multigrid' preconditioner as in the tutorial, I get a seg fault assembling the bilinear form. According to valgrind it happens in the BlockJacobiPreconditioner
==19959== Process terminating with default action of signal 11 (SIGSEGV)
==19959== Access not within mapped region at address 0xB104D5C0
==19959== at 0x14DBE9B7: ngla::BlockJacobiPrecond<double, double, double>::BlockJacobiPrecond(ngla::SparseMatrix<double, double, double> const&, std::shared_ptr<ngstd::Table<int> >) (blockjacobi.cpp:454)
I don't get the segfault if I specify 'local', 'direct', or 'bddc'.
If I don't specify a preconditioner, I can assemble and solve with no issues.
The segfault with 'multigrid' occurs whether or not inverse="sparsecholesky" is set.
Second, I get a seg fault if I try to create an HDiv space for the error recovery method. An HDiv space probably doesn't make much sense in a 1D context. Is there another approach to estimating error for marking and refinement?
I'm attaching my code...
Thanks!
Dow Drake
Edit: Also it seems that setting a refinement flag and refinement aren't supported for 1D meshes.
and
for el in mesh.Elements(): mesh.SetRefinementFlag(el, el.nr > 5)
also produce seg faults.
It makes sense since 1D meshes must be created manually. It shouldn't be difficult to do the refinement in Python.
Last edit: 7 years 3 months ago by ddrake. Reason: to provide additional information
