Zero matrix
- Dori
2 years 6 months ago #4785
by Dori
Zero matrix was created by Dori
Upon running the following code, using dsf1 or dsf2, I get a matrix of zeroes. However, I am anticipating a non-zero matrix. What can be causing the error?
ngsglobals.msg_level=1
def topBottom():
geometry = SplineGeometry()
pnts = [ (0, 0), (0.5, 0), (1, 0), (1, 1), (0.5, 1), (0, 1) ]
lines = [ (pnums[0], pnums[1], "gamma1", 1, 0),
(pnums[1], pnums[2], "gamma2", 2, 0),
(pnums[2], pnums[3], "gamma2", 2, 0),
(pnums[3], pnums[4], "gamma2", 2, 0),
(pnums[4], pnums[5], "gamma1", 1, 0),
(pnums[5], pnums[0], "gamma1", 1, 0),
(pnums[1], pnums[4], "gammaf", 1, 2)]
for p1,p2,bc,left, right in lines:
geometry.Append( ["line", p1, p2], bc=bc, leftdomain=left, rightdomain=right)
geometry.SetMaterial(1, "Domain1")
geometry.SetMaterial(2, "Domain2")
return geometry
mesh = Mesh(topBottom().GenerateMesh (maxh=0.1))
V = VectorL2(mesh, order=1, dgjumps=True)
Q = H1(mesh, order=1, definedon=mesh.Boundaries("gammaf"), dirichlet="gamma1|gamma2")
X=FESpace([V,Q])
(u,p),(v,q)=X.TnT()
dsf1=dx(element_boundary=True,definedon=mesh.Boundaries("gammaf"))
dsf2=dx(skeleton=True,definedon=mesh.Boundaries("gammaf"))
a=BilinearForm(X,check_unused=False)
a+=(p*(v-v.Other())*n+q*(u-u.Other())*n)*dsf2
_,_,vals = a.Assemble().mat.COO()
npvals = vals.NumPy()
print('assemble values = ', (npvals*npvals).sum())
def topBottom():
return geometry
X=FESpace([V,Q])
(u,p),(v,q)=X.TnT()
2 years 6 months ago #4787
Replied by joachim on topic Zero matrix
Hi Dori,
you are integrating over an internal interface, and you want to access functions from the left, the right, and the interface, right ?
This is not fully supported in NGSolve. Internal interfaces are treated as faces inside the domain, and 'u' and 'u.Other()' refer to the left and right volume elements.
Way out:
Q1 = H1(mesh, order=1)
Q = Compress(Q1, active_dofs=Q1.GetDofs(mesh.Boundaries("gammaf")))
Then you can access functions from Q in the volume, but you pay only for dofs at the interface.
- Joachim
Way out:
- Joachim
