Stokes iTutorial
7 years 3 months ago - 7 years 3 months ago #586 by ddrake
Stokes iTutorial was created by ddrake
Hi
I was working through the Stokes iTutorial and noticed an issue.
In input blocks 9 and 10, I get an error:
V = H1(mesh, order=2, dirichlet="wall|inlet|cyl") V.order[TRIG]=3
AttributeError: 'ngsolve.comp.H1' object has no attribute 'order'
I eliminate the AttributeError if I change this line to:
V.SetOrder(element_type=TRIG, order=3)
But instead of the expected output, I get this:
V.ndof = 1702 , Q.ndof = 2382
--------------------------------------------------------------------------- RuntimeError Traceback (most recent call last) <ipython-input-20-6e302700a473> in <module>() 5 Q = L2(mesh, order=1) 6 X = FESpace([V,V,Q]) ----> 7 gfu = SolveStokes(X) 8 velocity = CoefficientFunction(gfu.components[0:2]) 9 Draw(velocity, mesh, "vel") <ipython-input-6-6f8714cf1452> in SolveStokes(X) 16 res = gfu.vec.CreateVector() 17 res.data = -a.mat * gfu.vec ---> 18 inv = a.mat.Inverse(freedofs=X.FreeDofs(), inverse="umfpack") 19 gfu.vec.data += inv * res 20 return gfu RuntimeError: UmfpackInverse: Numeric factorization failed.
Dow
Last edit: 7 years 3 months ago by ddrake. Reason: Clarification
7 years 3 months ago #605 by ddrake
Replied by ddrake on topic Stokes iTutorial
The current version of this tutorial is working as expected.
Thanks!
Dow
7 years 3 months ago #609 by christopher
Replied by christopher on topic Stokes iTutorial
There is a cell where there is a note that with that choice of spaces the problem is instable. In that case the umfpack inverse fails. We correct that afterwards with the correct choice of spaces.
