Questions regarding FE spaces and DG
- arshiaf6
2 years 7 months ago #4721
by arshiaf6
Questions regarding FE spaces and DG was created by arshiaf6
I hope this message finds you well. I had two questions regarding the Discontinuous Galerkin method and FE spaces which are as follows.
1. how are the surface integrals over the interior mesh facets calculated in L2 space as we do not have any nodes on the mesh element facets?
2. In the H1 space, the nodes are on the vertices/edges of the mesh elements. As these degrees of freedoms are shared between different adjacent elements, I was wondering if we actually can use Discontinuous Galerkin method in the H1 space even with dgjumps=True? In other words, does H1 space allow discontinuity between elements?
Thank you,
Arshia
Thank you,
Arshia
2 years 7 months ago #4731
by hvwahl
Replied by hvwahl on topic Questions regarding FE spaces and DG
Hi Arshia,
regarding 2: You can break up the continuity of the H1 space like this
fes = Discontinuous(H1(mesh, order=2))
Then every element gets it's own copy of previously coupled dofs and basis functions become element-wise local.
Best wishes,
Henry
Best wishes,
Henry
Time to create page: 0.172 seconds
