Problems with defining pressure BC for Stokes equation
- Raphael_S
2 years 8 months ago #4643
by Raphael_S
Problems with defining pressure BC for Stokes equation was created by Raphael_S
Hy everybody,I try to solve the Stokes equation. If I define a velocity BC (U on surface ‘bot’) everything works fine and the expected result and the calculated result correspond. But, if I define a pressure BC, the results do not correspond to my expectations. On the surface ‘left’ I defined a pressure of 2 MPa and on the right surface I defined a pressure of 0.2 MPa. The velocity on the other surfaces is 0. My problem is, that after solving the Stokes equation, the pressure field on the left and right surface, does not have the value of the BC. So also, the velocity field is quite strange.So, maybe somebody can help me to define the pressure BC correctly.Many thanks to all of you.
Followed you can find my code:
# V = Periodic(VectorH1(mesh,order=3, dirichlet='bot|top')) # velocity
Q = H1(mesh,order=2, dirichlet='left|right') # pressure
X = V * Q
# obtain test and trial functions
u, p = X.TrialFunction()
v, q = X.TestFunction()
# space for solution data
gfu = GridFunction(X)
# boundary condition
#uin = CoefficientFunction((U,0,0))
#gfu.components[0].Set(uin, definedon=mesh.Boundaries("bot"))
cf = CoefficientFunction([(2) if bc=="left" else (0.2) if bc=="right" else 0 for bc in mesh.GetBoundaries()])
# Set BC
gfu.components[1].Set(cf, definedon=mesh.Boundaries("left|right"))
nu = (eta/rho) # kinematic viscosity
SetNumThreads(24) #Anzahl der Kerne zum Parallelisieren
# right hand side of the equation
f = LinearForm(X)
# left hand side of the equation
a += stokes*dx
# calculate solution data
inv_stokes = a.mat.Inverse(X.FreeDofs(), inverse="sparsecholesky")
# calculate drag force
res.data = a.mat*gfu.vec
F_drag_j = InnerProduct(res,gfu_help.vec) * rho
# density free pressure --> pressure
gfu.components[1].vec.data.FV().NumPy()[:] = gfu.components[1].vec.data.FV().NumPy() * rho
# pressure solution field
pressure = gfu.components[1]
# Define a coefficient function for val
# Draw velocity
#Draw(Norm(gfu.components[0]), mesh, "velocity",sd=3)
Draw((gfu.components[0]), mesh, "velocity",sd=3) # Draw velocity
# Draw the pressure
#Draw(pressure,mesh) # Draw pressure
X = V * Q
# Set BC
f = LinearForm(X)
a += stokes*dx
# Draw velocity
# Draw the pressure
2 years 8 months ago #4644
by hvwahl
Replied by hvwahl on topic Problems with defining pressure BC for Stokes equation
Hi Raphael_S,
could you please provide a minimal (non)-working example? I ran the code below and this set the pressure correctly (although I'm not sure the equations make much sense in this form).
Best wishes, Henry
V = VectorH1(mesh, order=3, dirichlet='bottom|top') # velocity
X = V * Q
(u, p), (v, q) = X.TnT()
f = LinearForm(X)
stokes = 0.1*InnerProduct(grad(u), grad(v))+div(u)*q+div(v)*p - 1e-10*p*q
a += stokes*dx
print(gfu.components[1](mesh(1,0.5)))
print(gfu.components[1](mesh(0,0.5)))
Best wishes, Henry
X = V * Q
f = LinearForm(X)
a += stokes*dx
- Raphael_S
2 years 8 months ago #4647
by Raphael_S
Replied by Raphael_S on topic Problems with defining pressure BC for Stokes equation
Hy Henry, Many thanks for your support. As I see, I did not add the whole code. Sorry for this. Many thanks that you support me. Best wishes, Raphael
#from netgen.webgui import Draw as DrawGeo
from netgen import*
# Velocity
U = 5*10**3 # velcoity in mm/s
rho = 857.22*10**-3/10**9 # density of the oil // t/mm^3
eta = 0.022474*10**-6 # dynamic viscosity of the oil // N/mm^2*s
box = Box((0,0,0), (3,1,1))
geo = box
geo.faces.Min(X).name='left'
geo.faces.Max(X).name='right'
geo.faces.Min(Y).name='front'
geo.faces.Max(Y).name='back'
geo.faces.Min(Z).name='bot'
geo.faces.Max(Z).name='top'
mesh = Mesh(OCCGeometry(geo).GenerateMesh(maxh=0.1)).Curve(3)
#DrawGeo(geo)
# Define a finite element space
V = VectorH1(mesh,order=3,dirichlet='front|back|bot|top') # velocity
X = V * Q
# Set BC
f = LinearForm(X)
a += stokes*dx
# Draw velocity
#Draw((gfu.components[0]), mesh, "velocity",sd=3) # Draw velocity
# Draw the pressure
Draw(pressure) # Draw pressure
pInitLeft = gfu.components[1](mesh(0,0.5,0.5))
pInitRight = gfu.components[1](mesh(3,0.5,0.5))
## data visualisation / export
velocity = gfu.components[0]
nameOfFile = 'test'
#nameOfFile = 'Initial_Conditions'
# VTKOutput object
vtk = VTKOutput(ma=mesh,
coefs=[pressure,velocity],
names = ["pressure","velocity"],
filename=nameOfFile,
subdivision=0,
legacy = True)
# Exporting the results:
vtk.Do()
from netgen import*
# Velocity
geo = box
#DrawGeo(geo)
X = V * Q
# Set BC
f = LinearForm(X)
a += stokes*dx
# Draw velocity
# Draw the pressure
nameOfFile = 'test'
# VTKOutput object
subdivision=0,
legacy = True)
vtk.Do()
2 years 8 months ago #4649
by hvwahl
Dear Raphael,
if you post code that isn't working as expected, please make a minimal working example, i.e., remove all code that isn't relevant to the issue and that runs on a laptop. Something like this:
geo = Box((0,0,0), (3,1,1))
mesh = Mesh(OCCGeometry(geo).GenerateMesh(maxh=0.5))
V = VectorH1(mesh,order=2,dirichlet='front|back|bot|top') # velocity
Q = H1(mesh,order=1, dirichlet='left|right') # pressure
X = V * Q
a += ((eta/rho)*InnerProduct(grad(u), grad(v))+div(u)*q+div(v)*p - 1e-10*p*q) * dx
res = gfu.vec.CreateVector()
res.data = - a.mat*gfu.vec
print(gfu.components[1](mesh(0, 0.5, 0.5)))
print(gfu.components[1](mesh(3, 0.5, 0.5)))
which again results in the expected output for me.
Best wishes,
Henry
X = V * Q
Best wishes,
Henry
The following user(s) said Thank You: Raphael_S
Time to create page: 0.176 seconds
