Mesh Refinement Routines
2 years 8 months ago - 2 years 8 months ago #4638 by johannes_s
Hello.
i) Which refinement routine is used for local (adaptive) mesh refinements? I haven't found anything in the documentation.
ii) Is there a simple way to include an alternative routine like the one of Maubach in "Local Bisection Refinement for N-Simplicial Grids Generated by Reflection"?
iii) Are there already different refinement routines included?
Kind regards,
Johannes
Last edit: 2 years 8 months ago by johannes_s.
2 years 8 months ago #4645 by hvwahl
Replied by hvwahl on topic Mesh Refinement Routines
Hi Johannes,
regarding (i), the doc-string of the Mesh class states
 |  Refine(...)
 |      Refine(self: ngsolve.comp.Mesh, mark_surface_elements: bool = False, onlyonce: bool = False) -> None
 |      Local mesh refinement based on marked elements, uses element-bisection algorithm
regarding (iii) In the  Navier-Stokes workshop materials from the third NGSolve User Meeting, there is a script wich implements barycentric mesh refinement in python. This may be a good starting point to implement your own mesh refinement routine.
Best wishes
Henry
The following user(s) said Thank You: johannes_s
2 years 8 months ago #4648 by johannes_s
Replied by johannes_s on topic Mesh Refinement Routines
Hi, thanks for your answer. Is the bisection routine somewhere specified, that is, does the program use longest-edge bisection or the bisection routine of Maubach/Traxler?
Kind regards,
Johannes
Time to create page: 0.150 seconds
