BH curve
- lahoussaine
2 years 9 months ago #4620
by lahoussaine
BH curve was created by lahoussaine
Good morning community;
is there a way to implment bh curve using ngsolve :
i do somthing like
def nuf(u):
return Norm(grad(u))
nu=CoefficientFunction(nuf)
a+=nu*grad(u)*grad(v)*dx
but always i got nan values !
any tricks ?
i do somthing like
def nuf(u):
any tricks ?
- mrambausek
- Thank you received: 3
2 years 9 months ago #4621
by mrambausek
Replied by mrambausek on topic BH curve
Dear Lahoussaine,
what is the actual model you want to implement?
"Norm(grad(u))" does not seem to a suitable model in first place, as it leads to a singular matrix for grad(u) = 0.
- lahoussaine
2 years 9 months ago #4625
by lahoussaine
Replied by lahoussaine on topic BH curve
I want something like
1/(B**3+B**2+B )
or :
3.8*exp(2.17*B*
+396.2
I ve tried those expression but it gives always NAN;
Thankes for your reply
1/(B**3+B**2+B )
or :
3.8*exp(2.17*B*
+396.2I ve tried those expression but it gives always NAN;
- mrambausek
2 years 9 months ago #4626
by mrambausek
TBH, I have never seen any magnetic model like that (which might not mean a lot...)
I can't see how the first one could give something reasonable for B=0.
Before using a nonlinear model, did you have a working version for a constant "nu"?
I fear, we need much more information to be able to help you.
- lahoussaine
2 years 9 months ago #4627
by lahoussaine
def nuf(u):
IfPos(2.28-B,(1/(-0.003995*B**3+0.005956*B**2+0.00646*B + 0.001925)), ((1902.211*B-4266.42343)/0.016694669))
Here is my formule, but it doesn't work
The problem is whenever i put norm(
it returns NAN
even if the formula is well defined( 1/(B**2+1) for example )
Thank you and Sorry to not be claire
it returns NANeven if the formula is well defined( 1/(B**2+1) for example )
- mrambausek
2 years 9 months ago #4628
by mrambausek
Unfortunately, I still miss some information: how is "B" defined?
Where does the "Norm" enter in "1/(B**2 + 1)
Which command did you use for assembly? Where exactly do you get NaN? Already in the matrix or only after solving, i.e. in the solution?
Could you maybe post a complete minimal example that reproduces your problem?
