How to set up finite element space for 1d periodic mesh correctly?
2 years 11 months ago - 2 years 11 months ago #4548 by dwersd
Hallo!
I'm trying to define a finite element space on 1d periodic mesh with the following simple codes:
from ngsolve.meshes import Make1DMesh
n = 3
mymesh = Make1DMesh(n, periodic = True)
fes = Periodic(H1(mymesh,order=1))
a += u*v*ds
print(a.mat)
When I ran these codes, it said "used dof inconsistency
(silence this warning by setting BilinearForm(...check_unused=False) )"
with "print(a.mat)" to be:
Row 0: 0: 2 1: 0 2: 0
Row 1: 0: 0 1: 0 2: 0
Row 2: 0: 0 1: 0 2: 0
Row 3:
this mass matrix is definitely not correct for periodic setting.
Does anyone know what's wrong in the codes? Thank you very much!
Last edit: 2 years 11 months ago by dwersd.
2 years 11 months ago #4549 by mneunteufel
u*v*ds
you are integrating only over the boundary of the mesh. To obtain the mass matrix you have to use dx instead of ds.
2 years 11 months ago #4551 by dwersd
Thank you Michael! I'm new to NGsolve. May I ask another simple question?
After I changed ds to dx, "print(fes.ndof)" is 4 instead of 3 (actual nodes number). Moreover if I set the gridfunction below
gfu.Set(cos(2*pi*x))
the first entry does not coincide with the 4th entry. So it seems to break the periodic condition. Do you have any idea?
2 years 11 months ago #4553 by mneunteufel
the behavior is correct. If you plot fes.FreeDofs() you observe that the last dof is “not-free”, it depends on the first one due to periodicity. If you draw the function you get a periodic function
from ngsolve.internal import viewoptions
visoptions.showsurfacesolution=True
viewoptions.drawedges=1
visoptions.deformation=1
Draw(gfu, mymesh, "gfu")
With fes = Compress(Periodic(H1(mymesh,order=1))) the last dof is compressed out and you have only 3 dofs left.
Time to create page: 0.184 seconds
