Space elements order through numpy
- alecontri
2 years 11 months ago - 2 years 11 months ago #4529
by alecontri
Space elements order through numpy was created by alecontri
I was doing a convergence test, feeding the elements of a numpy array as the parameter "order" in the space definition. I noticed that no matter the number I was giving, the convergence was as if order = 1. This is a simple example where I show the order before and after the space definition:
Is it a bug or is it supposed to be like this (of course writing
solved the problem)?
Thanks a lot
geo.AddRectangle( (0, 0), (1, 1), bcs = ("bottom", "right", "top", "left"))
mesh.Curve(1)
order_n = np.array([4])
print(order_n[0])
V = H1(mesh, order=order_n[0], dirichlet="bottom|right|left|top")
print(V.globalorder)
order=int(order_n[0])
Thanks a lot
Last edit: 2 years 11 months ago by alecontri.
2 years 11 months ago #4532
Replied by christopher on topic Space elements order through numpy
Hm yes, we expect an int python type here and numpy gives a numpy.int64... But asking for all the possible types would also be too much in the code... I think we have to stick here to convert the parameter to int.
The following user(s) said Thank You: alecontri
