Netgen over a remote connection requiring display
- JamesElgy
3 years 1 month ago #4512
by JamesElgy
Netgen over a remote connection requiring display was created by JamesElgy
HI All,
I am trying to use Netgen over a remote desktop connection via an ubuntu terminal without an attached display. My understanding is that
$ netgen -geofile=example.geo -meshfile=example.vol - coarse -batchmode
would generate a mesh of example.geo without opening a gui interface. Is that correct? I am getting tkinter errors about connecting to a display:
File "/home/james/.local/bin/netgen", line 8, in <module>
sys.exit(main())
File "/home/james/.local/lib/python3.10/site-packages/netgen/__main__.py", line 45, in main
from .gui import win
File "/home/james/.local/lib/python3.10/site-packages/netgen/gui.py", line 48, in <module>
StartGUI()
File "/home/james/.local/lib/python3.10/site-packages/netgen/gui.py", line 20, in StartGUI
win = Tk()
File "/usr/lib/python3.10/tkinter/__init__.py", line 2299, in __init__
self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: couldn't connect to display "localhost:0.0"
Regards,
James
sys.exit(main())
StartGUI()
win = Tk()
Regards,
James
3 years 1 month ago #4513
Replied by christopher on topic Netgen over a remote connection requiring display
in your command is the space between the - and coarse on purpose or a copy mistake?
Because if I remove the space your command works for me.
But how did you install ngsolve? Using provided installer, apt or pip installer?
- JamesElgy
3 years 1 month ago #4514
by JamesElgy
Replied by JamesElgy on topic Netgen over a remote connection requiring display
Hi Christopher,
Thanks for the prompt reply.
The space between the - and coarse was a copying mistake I made when I typed my original forum post.
I've installed ngsolve via the pip installer.
Regards,
James
Regards,
James
3 years 4 weeks ago - 3 years 4 weeks ago #4517
by matthiash
Replied by matthiash on topic Netgen over a remote connection requiring display
Hi James,
The "netgen" executable in the pip installer is actually a python script, not implementing all the options from the "legacy" executable you get when you compile the code yourself. (has to do with python packaging and linkage).
In your case I would write a short python script to do the meshing and run it:
geom = CSGeometry("some_file.geo")
mesh = geom.GenerateMesh(meshsize.coarse)
mesh.Save("mesh.vol.gz")
Last edit: 3 years 4 weeks ago by matthiash.
The following user(s) said Thank You: JamesElgy
