Periodic Boundary Conditions for an STL Geometry
3 years 3 months ago - 3 years 3 months ago #4435 by agupta87
Hey Everyone,
I am a newbie at Netgen/NGSolve. I'm currently wanting to mesh (and eventually solve!) a PDE on a geometry defined by an STL file. Because I have a large number of STL files, I intend to use the Python libraries for Netgen and NGSolve (no GUI). Currently, I create an STL file through OpenSCAD and import it using:
import netgen.libngpy as libngpy geom = libngpy._stl.STLGeometry(STL_PATH)
This enables me to import the STL geometry. I then generate a mesh using the GenerateMesh() function.
mesh = geom.GenerateMesh()
By generating the mesh through Netgen, I'm able to select the different surfaces in my STL file. I was able to select 8 of my 10 surfaces and identified them to be Dirichlet boundary conditions. the remaining two surfaces need to be made Periodic. I can't find a way to do this given a Mesh. The only way I can make two surfaces periodic is by identifying those surfaces in the geometry itself. But the only way to identify those surfaces is to create a Mesh and extract the points out.
# creates list of length N of empty lists for N surfaces allpoints = np.zeros(mesh.GetNFaceDescriptors(), dtype=object) for z in range(len(allpoints)):     allpoints[z] = for elem in mesh.Elements2D(): # adds points to the Nth list that correspond to the Nth surface     allpoints[elem.index-1].append( list(mesh[elem.vertices[0]]) ) for z, zz in enumerate(allpoints):     ptz = np.asarray(zz)     means, stds = np.mean(ptz, axis=0), np.std(ptz, axis=0)    # attempts to capture the boundaries representing the hole [DIRICHLET, 4]    if np.all(abs(means)<HOLEY/2.) and abs(means[2])<THICKNESS/4.:         mesh.SetBCName(z, 'hole')     # attempts to capture the side edges of the plate [DIRICHLET, 4]     elif np.any(abs(means) == PLATE/2. ):         mesh.SetBCName(z, 'faredge')     # attempts to capture the boundaries that need to be periodic [PERIODIC, 2]     elif abs(means[2]) == THICKNESS/2.:         mesh.SetBCName(z, 'periodic')
I was wondering if someone could help me set boundary conditions accordingly for the two opposing faces in my STL file. I've attached my STL file for your viewing. There's a really really small hole in the center ! The sides I want to make periodic are two sides that are normal to the z-axis..
Thanks,
Adyota
EDIT: I'm unsure why I can't upload my STL file, though I have no problem sending it by email or uploading it elsewhere for your viewing. I'm not sure where to upload it though without having to create an account ! :-)
Last edit: 3 years 3 months ago by agupta87.
