Read msh file
3 years 3 months ago #4432
by mrbenson
Read msh file was created by mrbenson
I'm looking for reading a msh file (version 2.2), ReadGmsh (from netgen.read_gmsh) can do that. I read the documention and i didn't find any relevant about it. It sounds not so clear about information needed :
- does ReadGmsh take into account physical (first) or elementary (second) tags.
- does ReadGmsh need PhysicalNames ? If yes, are they related to elementary or physical tag ?
Best regards.
PS : I'd be great to offer import msh file in netgen
Best regards.
- mrambausek
- Thank you received: 3
3 years 3 months ago #4434
by mrambausek
Replied by mrambausek on topic Read msh file
from a quick look at the code I would recommend to use both physical tags and physical names.
If the import does not work it should be possible to quickly fix that. Just let me know and provide a simple example that fails.
In addition, you may have a look into meshio ( github.com/nschloe/meshio ) which supports conversion
between a lot of different formats, including gmsh and netgen.
Matthias R.
Matthias R.
