MacOS: Installation: "Frameworks" path missing at NGSolve-6.2.1804.dmg?
7 years 4 months ago #542 by charge
Hi everybody,
I tried to install Netgen on my MacOS by downloading NGSolve-6.2.1804.dmg. I dragged and dropped this file to my Applications folder and then added the following commands to my .bash_profile:
#netgen path variables
export PYTHONPATH=$PYTHONPATH:/Applications/Netgen.app/Contents/Resources/li b/python3.6/site-packages:.
export NETGENDIR=/Applications/Netgen.app/Contents/MacOS
export DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$NETGENDIR
export DYLD_FRAMEWORK_PATH=$DYLD_FRAMEWORK_PATH:$NETGENDIR/../Frameworks
export PATH=$NETGENDIR:$PATH
However when trying to start "netgen" in the command line, I get the following error message:
dyld: Library not loaded: @executable_path/../Frameworks/Python.framework/Versions/3.6/Python
Referenced from: /Applications/Netgen.app/Contents/MacOS/netgen
Reason: image not found
Abort trap: 6
Then I noticed that there is no folder "Frameworks":
$ cd $NETGENDIR/..
$ pwd
$ ls
Info.plist MacOS Resources
Am I doing something completely wrong or is there a problem with the "NGSolve-6.2.1804.dmg" installation file?
Thanks in advance and best regards
7 years 4 months ago #543 by joachim
it does not find Python. Are you sure you have Python 3.6 installed ?
Do you have the file
/Library/Frameworks/Python.framework/Versions/3.6/Python
Since now all frameworks we use are standard, we don't have any framework inside the Netgen app.
7 years 4 months ago #544 by charge
Hi Joachim,
Thank you for your quick reply!
I have Python 3.6 installed, but through Anaconda which does not install Python with a framework build: groups.google.com/a/continuum.io/forum/#...anaconda/1rX3A1Noi9Q
Is there any workaround to also let netgen work with the python version from anaconda?
Thanks,
7 years 4 months ago #545 by charge
Hi Joachim,
I got a step further. I linked the anaconda library libpython3.6m.dylib against the framework library requested:
sudo ln -s /anaconda3/lib/libpython3.6m.dylib ./Python
Now I can successfully start "netgen". However, when I try to import netgen or ngsolve to python3, it always crashes:
Python 3.6.5 |Anaconda, Inc.| (default, Apr 26 2018, 08:42:37)
[GCC 4.2.1 Compatible Clang 4.0.1 (tags/RELEASE_401/final)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> from ngsolve import *
Fatal Python error: PyThreadState_Get: no current thread
Abort trap: 6
Do you might have another advice concerning this error?
Thanks and best regards,
7 years 4 months ago #546 by charge
PS: sudo ln -s /anaconda3/lib/libpython3.6m.dylib ./Python
was executed in
So effectively the command was:
sudo ln -s /anaconda3/lib/libpython3.6m.dylib /Library/Frameworks/Python.framework/Versions/3.6/Python
Time to create page: 0.175 seconds
