- Thank you received: 24
Local mesh diameter
7 years 4 months ago #535
by hvwahl
Local mesh diameter was created by hvwahl
I want to compute the actual maxh of a given mesh after it is built. My idea was to iterate through the mesh and call specialcf.mesh_size.Norm(). Something along these lines:
This does not give me the desired result. I'd appreciate any help
Best wishes,
Henry
mesh = unit_square.GenerateMesh(maxh=h_max)
for e in mesh.Elements2D():
print(specialcf.mesh_size)
Best wishes,
Henry
7 years 4 months ago #536
by cwinters
Replied by cwinters on topic Local mesh diameter
the function "specialcf.mesh_size" is a CoefficientFunction. Therefore it needs an integration point to evaluate the mesh size. If you have an NGSolve mesh can call "mesh(x,y)" to get an integration point with the coordinates x,y.
But I would suggest an easier solution:
In the first step you calculate the volume of each element. Knowing that the volume of a simplex is connected to the Jacobian determinant (which scales h^dim) you get an estimate for the mesh size.
h_max = 0.2
ngmesh = unit_square.GenerateMesh(maxh=h_max)
elvol = Integrate(CoefficientFunction(1),mesh,element_wise=True)
h = [(2*vol)**(1/2) for vol in elvol]
print(min(h),max(h))
The following user(s) said Thank You: hvwahl
7 years 4 months ago #537
by hvwahl
Replied by hvwahl on topic Local mesh diameter
Hi Christoph,
tank you for your help! Your easier solution, has worked well. For 3d I can similarly use
or have I messed something up in the constant?
Best wishes,
henry
h = [(3*vol)**(1/3) for vol in elvol]
Best wishes,
henry
7 years 4 months ago #538
by cwinters
for 3d it should be
Here you can find the volume of a simplex . The constant is actually the factorial of the spatial dimension.
for 3d it should be
h = [(6*vol)**(1/3) for vol in elvol]
7 years 4 months ago #539
by hvwahl
Hi Christoph,
thanks! Strangely however, using the constant = 6, consistently gives me a max(h) which is larger than the h_max I used to mesh a cube (of side length 2) by a factor of 21/3 (i.e., constant
). Do you have any idea why this would be the case?
Best wishes,
Henry
Best wishes,
Henry
7 years 4 months ago #540
by cwinters
Hi Henry,
the maxh argument in GenerateMesh is not a strict upper bound.
Therefore the elements might be slightly larger than the defined maxh.
Time to create page: 0.207 seconds
