Error with setting the boundary condition
  • omar
  • New Member
  • New Member
3 years 5 months ago #4378 by omar
I am trying to solve Poisson equation on a contraction step problem. I get an error to set dirichlet boundary condition at different boundaries.
Here is the part of the code:
import netgen.geom2d  as  geom2d
from netgen.meshing import Element0D, Element1D, Element2D, MeshPoint, FaceDescriptor, Mesh
from netgen.csg import Pnt
ngsglobals.msg_level =2
# %% Geometry generation  (points definition)
geo = geom2d.SplineGeometry()
p1 = geo.AppendPoint (0,0)
p2 = geo.AppendPoint (3,0)
p3 = geo.AppendPoint (3,0.1)
p4 = geo.AppendPoint (2,0.1)
p5 = geo.AppendPoint (2,1)
p6 = geo.AppendPoint (0,1)
# (Boundaries definition)
geo.Append (["line", p1, p2],bc=1)  # bottom
geo.Append (["line", p2, p3],bc=2)  # outlet
geo.Append (["line", p3, p4],bc=3)  # horizontal
geo.Append (["line", p4, p5],bc=4)  # vertical
geo.Append (["line", p5, p6],bc=5)  # top
geo.Append (["line", p6, p1],bc=6)  # Inlet
fes = H1(mesh, order=2, dirichlet=[1,2])
The error happens for the last line:
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. ngsolve.comp.H1(mesh: ngsolve.comp.Mesh, **kwargs)
Invoked with: <netgen.libngpy._meshing.Mesh object at 0x000002303900E530>; kwargs: order=2, dirichlet=[1, 2]
Thanks in advance
3 years 5 months ago #4379 by mneunteufel
Hi omar, there are two types of Mesh object, one from NGSolve one from Netgen. Due to from netgen.meshing import Element0D, Element1D, Element2D, MeshPoint, FaceDescriptor, Mesh the Netgen mesh will be used, but you need the NGSolve mesh.Removing the import of the Netgen Mesh should fix it. Best,Michael
  • omar
  • New Member
  • New Member
3 years 5 months ago #4380 by omar
Unfortinately I still have the same error.
Here is my updated code:
mesh = geo.GenerateMesh (maxh=0.1)
And this is the error message:
Invoked with: <netgen.libngpy._meshing.Mesh object at 0x000001722D060BF0>; kwargs: order=2, dirichlet=[1, 2
3 years 5 months ago #4394 by mneunteufel
The netgen mesh needs to be converted into the NGSolve mesh.
Replace
by
mesh = Mesh(geo.GenerateMesh (maxh=0.1))
The following user(s) said Thank You: omar
  • omar
  • New Member
  • New Member
3 years 4 months ago #4397 by omar
Thank you so mush
That solved the issue
