[Bug] Defining bcnames for 2D geometries
7 years 4 months ago #531 by niushi200
As shown in the following code, when I partially prescribed boundary conditions for the edge 3, the NGSPy marked both edge 1 and edge 3 as 1.
I think the correct way is to makr edge 3 only with id of 3.
So is this a bug? Is there any way to avoid this problem?
from netgen.geom2d import SplineGeometry geo = SplineGeometry() p1 = geo.AppendPoint (0,0) p2 = geo.AppendPoint (1,0) p3 = geo.AppendPoint (1,1) p4 = geo.AppendPoint (0,1) geo.Append (["line", p1, p2]) geo.Append (["line", p2, p3]) geo.Append (["line", p3, p4],bc="inlet") geo.Append (["line", p4, p1]) mesh = geo.GenerateMesh (maxh=0.8)
# surfid 0 p1 p2 trignum1 trignum2 domin/surfnr1 domout/surfnr2 ednr1 dist1 ednr2 dist2 edgesegmentsgi2 8 1 0 1 5 0 96898656 1 0 1 0 1 0.4999999999999944 1 0 5 2 0 96898656 1 0 1 0.4999999999999944 1 1 2 0 2 6 0 96898656 1 0 2 0 2 0.4999999999999944 2 0 6 3 0 96898656 1 0 2 0.4999999999999944 2 1 1 0 3 7 0 96898656 1 0 3 0 3 0.4999999999999944 1 0 7 4 0 96898656 1 0 3 0.4999999999999944 3 1 4 0 4 8 0 96898656 1 0 4 0 4 0.4999999999999944 4 0 8 1 0 96898656 1 0 4 0.4999999999999944 4 1 bcnames 5 1 wall 2 default 3 default 4 default 5 default
Thanks
Bin
7 years 4 months ago #534 by cwinters
there seems to be a bug. I already created a merge request on that.
For now, if all your segments have a string as bc, everything works fine.
The following user(s) said Thank You: niushi200
