Loading geometry from command line
3 years 5 months ago #4356 by brittany-e
Hello there,
 I just installed Netgen on my MBP.  From the command line I can open it from command line with
netgen
If I'm in the folder containing the geometries, I can open one, e.g. File -> Load Geometry -> sculpture.geo
But I cannot do this from the command line using
netgen sculpture.geo
(netgen opens but geometry does not load).
At this point I have not added to my bash start up file the following: export PYTHONPATH=$PYTHONPATH:/Applications/Netgen.app/Contents/Resources/lib/python3.8/site-packages:.
export NETGENDIR=/Applications/Netgen.app/Contents/MacOS
export DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$NETGENDIR
export DYLD_FRAMEWORK_PATH=$DYLD_FRAMEWORK_PATH:$NETGENDIR/../Frameworks
export PATH=$NETGENDIR:$PATH
When I do, and I again call
netgen
I get the error below. Can you provide some advice on what to do?
dyld: Library not loaded: /Library/Frameworks/Python.framework/Versions/3.8/Python  Referenced from: /Applications/Netgen.app/Contents/MacOS/netgen  Reason: image not foundzsh: abort      netgen
ALSO: are you aware that this link is broken:  ngsolve.org/docu/latest/install/gettingstarted.html
although this one works:  docu.ngsolve.org/latest/install/gettingstarted.html
Thanks!
3 years 5 months ago #4357 by matthiash
Hello!
How did you install Netgen? The behavior that "netgen sculpture.geo" is not showing a geometry indicates that you are using the "pip install netgen" method.
(Side note: We had to reimplement the netgen main file in python for the pip installers, and most features are still missing. In the .dmg installers the geometry should be loaded with this command).
The variables you set afterwards are only necessary, if you use the .dmg installer (not for the pip installer).
Could it be you tried both? In this case I would remove the .dmg installation (/Applications/Netgen.app) and the environment variables. The .dmg bundle needs python 3.8 (seems you have a different version installed, that's why it's not working.)
The broken link is fixed, thank's for the hint!
We will implement the geometry loading from command line, I will reply here when a new (nightly) version is available.
3 years 5 months ago #4360 by matthiash
A new (prerelease) version is available on pip, you can get it with
pip install --pre ngsolve
Time to create page: 0.144 seconds
