multi-grid with vector valued space
3 years 7 months ago #4312 by walker_tr9
This is related to a recent post of mine.
If I define a FE space like this:  H1(mesh, order=1, dim=2)
then when if I solve my elliptic system with geometric multi-grid, it is fine.  However, if I use "h1amg", then it "silently" crashes; it just exits and says nothing.
However, if I define the space like this:
H1(mesh, order=1) ** 2
then the reverse happens.  I can use "h1amg" no problem, but if I use "multigrid", then it "silently" crashes again.
What is the deal here?
3 years 7 months ago #4326 by joachim
The "h1amg" is now (will be online tomorrow)  throwing an exception when applied to H1(dim=2)
The geometric multigrid is working for both versions, H1(dim=2) as well as H1()**2 in my tests. Can you send your example ?
3 years 7 months ago #4329 by walker_tr9
Do I need to update my NGsolve?
It will take some time to produce a "standalone" example.
3 years 7 months ago #4333 by walker_tr9
Here is a standalone example. It seems to crash when doing the assembly...
# make the mesh
geo.AddRectangle( (0,0), (1,1), bc = "Gamma")
mesh = Mesh(geo.GenerateMesh(maxh=1.0))
for r in range(4):
print(mesh.GetBoundaries())
zero_vec = CoefficientFunction((0.0, 0.0))
fes_V = H1(mesh, order=1) ** 2
a_form = BilinearForm (fes_V, symmetric=False)
# setup weak formulation
qq = fes_V.TrialFunction()
pp = fes_V.TestFunction()
a_form += InnerProduct(grad(qq),grad(pp)) * dx
a_form += InnerProduct(qq,pp) * dx
f_form = LinearForm(fes_V)
f_vec = CoefficientFunction((x, y))
f_form += InnerProduct(f_vec,pp) * dx
# this does NOT work (silently crashes; it doesn't make it to the "Attempt to solve..." statement below)
c = Preconditioner(a_form, "multigrid") # Register 'c' to 'a' BEFORE assembly
# # this does work
# c = Preconditioner(a_form, "h1amg") # Register 'c' to 'a' BEFORE assembly
print("Attempt to assemble...")
a_form.Assemble()
f_form.Assemble()
print("Attempt to solve...")
# Conjugate gradient solver
inv = CGSolver(a_form.mat, c.mat, maxsteps=5000) #, precision=1e-12)
# do the solve
vec_data = inv * f_form.vec
print("We solved it!")
input("Press Enter to finish...")
3 years 5 months ago #4402 by walker_tr9
Did this ever get fixed? I still get the error with that sample code I gave.
