MultiVector class and MPI compatibility
3 years 7 months ago #4221 by aujxn
I am converting an existing library to run in parallel with MPI. The library makes extensive use of the MultiVector class.
 I have found that taking the InnerProduct of a MultiVector with parallel vectors computes the inner product of the local components for each rank. Is this the desired functionality or is MultiVector not compatible with MPI? Can I apply parallel operators, such as mumps inverse, to parallel MultiVectors?
Example:
from netgen.geom2d import unit_square from ngsolve import grad, dx import ngsolve as ng import netgen from mpi4py import MPI import numpy as np import logging comm = MPI.COMM_WORLD logging.basicConfig(         level=logging.DEBUG,         filename=f'rank{comm.rank}.txt',         format='%(asctime)s %(funcName)s:%(lineno)d\n%(message)s'         ) h = 0.1 if comm.rank == 0:     ngmesh = unit_square.GenerateMesh(maxh=h).Distribute(comm) else:     ngmesh = netgen.meshing.Mesh.Receive(comm) mesh = ng.Mesh(ngmesh) fes = ng.H1(mesh, order=3, dirichlet=".*") u,v = fes.TnT() a = ng.BilinearForm(grad(u)*grad(v)*dx) with ng.TaskManager():     a.Assemble() n = fes.ndof logging.debug(f'Degrees of freedom of H1 on current rank: {n}\n' +               f'FreeDofs bit array: {fes.FreeDofs()}\n') # Create random value MultiVectors gfu = ng.GridFunction(fes) mv0 = ng.MultiVector(gfu.vec, 2) mv1 = ng.MultiVector(gfu.vec, 2) rng = np.random.default_rng() random_vecs = rng.random((4, n)) mv0[0].FV().NumPy()[:] = random_vecs[0, :] mv0[1].FV().NumPy()[:] = random_vecs[1, :] mv1[0].FV().NumPy()[:] = random_vecs[2, :] mv1[1].FV().NumPy()[:] = random_vecs[3, :] # MultiVector inner product test inner = ng.InnerProduct(mv0, mv1) logging.debug(f'Inner product of 2 MultiVectors:\n{inner}\n') # Inner product of MultiVector local components local_inner = np.zeros((2, 2)) for i in range(2):     for j in range(2):         local_inner[i, j] = ng.InnerProduct(mv0[i].local_vec, mv1[j].local_vec) logging.debug(f'Inner product of 2 MultiVectors local components:\n{local_inner}\n') # Manual inner product of MultiVector manual_inner = np.zeros((2,2)) for i in range(2):     for j in range(2):         manual_inner[i, j] = ng.InnerProduct(mv0[i], mv1[j]) logging.debug(f'Pairwise inner product of parallel vectors:\n{manual_inner}')[/i][/i]
Output:
2022-03-02 13:31:26,952 main:39 Degrees of freedom of H1 on current rank: 46 FreeDofs bit array: 0: 1111111111111111111111111111111111111111111111 2022-03-02 13:31:26,953 main:55 Inner product of 2 MultiVectors:   10.517 10.3929  10.6328 11.6122 2022-03-02 13:31:26,954 main:62 Inner product of 2 MultiVectors local components: [[10.51703725 10.3928831 ]  [10.63276183 11.61222237]] 2022-03-02 13:31:26,955 main:69 Pairwise inner product of parallel vectors: [[270.4623489  276.32998277]  [284.52705911 289.39745476]]
Austen
3 years 7 months ago #4223 by joachim
Hi Austen,
thank you for the bug report, is now fixed,
