Import error when called netgen.gui on Big Sur
3 years 8 months ago #4171
by sat
Import error when called netgen.gui on Big Sur was created by sat
Hello everybody,
I try to test the i-tutorial of 4.2 Constructive Solid Geometry because I want to start 3D FEM on MacOS 11.6.
But when I import netgen.gui, I face Tcl Error
TclError Traceback (most recent call last)
<ipython-input-1-b84eefae61c3> in <module>
----> 1 import netgen.gui
2 from ngsolve import Draw, Redraw # just for visualization
/Applications/Netgen.app/Contents/Resources/lib/python3.9/site-packages/netgen/gui.py in <module>
16 import os
17 if not "NETGEN_DOCUMENTATION_RST_FORMAT" in os.environ:
---> 18 StartGUI()
19
20 def Snapshot(w,h, filename=None):
/Applications/Netgen.app/Contents/Resources/lib/python3.9/site-packages/netgen/gui.py in StartGUI()
9 win.tk.eval('lappend ::auto_path ' + netgen._netgen_bin_dir)
10 # load with absolute path to avoid issues on MacOS
---> 11 win.tk.eval('load "'+netgen._netgen_lib_dir.replace('\\','/')+'/libgui[info sharedlibextension]" gui')
12 win.tk.eval( netgen.libngpy._meshing._ngscript)
13
TclError: dlopen(/Applications/Netgen.app/Contents/MacOS/libgui.dylib, 6): Symbol not found: _OBJC_CLASS_$_NSOpenGLContext
Referenced from: /Applications/Netgen.app/Contents/MacOS/libgui.dylib
Expected in: flat namespace
in /Applications/Netgen.app/Contents/MacOS/libgui.dylib
I believe that NSOpenGLContext is deprecated.
Can't I use Netgen for 3D visualization through jupyter notebook or python directly?
I would appreciate it if you give me any comments.
Greetings,
Sat
16 import os
---> 18 StartGUI()
19
13
Greetings,
Sat
