Boundary Finite Element Spaces
- walker_tr9
- Senior Member
3 years 10 months ago #4143
by walker_tr9
Boundary Finite Element Spaces was created by walker_tr9
I'm having some trouble. I would like to have a finite element space defined on the boundary mesh of a bulk mesh. Fore example, piecewise linear on the boundary of a square. So I did this:
bdy_H1 = H1(mesh, order=1, definedon="top|left|right|bottom")
Is this right? If so, I now create a GridFunction:
bdy_u = GridFunction(bdy_H1, "bdy_func")
bdy_u.Set(1)
Here I set it to 1, but it could be anything. In fact, bdy_u could end up being the solution of some boundary PDE.
Anyway, I now want to plot bdy_u. From what I have read, I have to create a bulk GridFunction, and somehow transfer the bdy_u values to the bulk GridFunction. But I don't know how to do that.
-Shawn
bdy_u.Set(1)
-Shawn
3 years 10 months ago #4144
by schruste
Replied by schruste on topic Boundary Finite Element Spaces
Hi Shawn,
The Set(..) sets values on specified domains. If nothing is specified it will set on the whole *volume* mesh (where your GridFunction is not defined). You need to specify the part of the boundary you want to prescribe a function. If it's on the whole boundary simply use .Set(..., BND) otherwise use .Set(..., mesh.Boundaries("...")).
- walker_tr9
- Senior Member
3 years 10 months ago #4145
by walker_tr9
Replied by walker_tr9 on topic Boundary Finite Element Spaces
Ok, so I do this:
mesh = Mesh (unit_square.GenerateMesh(maxh=0.02))
# standard FE space
V = H1(mesh, order=1, dirichlet=[])
# my boundary FE space
bdy_u.Set(1)
bdy_u_ext = GridFunction(V)
bdy_u_ext.Set(bdy_u, BND)
Draw(bdy_u_ext)
But the plot just shows zero everywhere.
If I made a CoefficientFunction defined to be 1 (on the boundary), then there is a way to plot that. But that is not an option. I need to be able to plot a finite element function that is only defined on the boundary.
# standard FE space
bdy_u.Set(1)
Draw(bdy_u_ext)
- walker_tr9
- Senior Member
3 years 10 months ago #4146
by walker_tr9
Ok, I found this explanation, which definitely helps!
ngsolve.org/forum/ngspy-forum/976-how-to...ace-on-the-interface
- walker_tr9
- Senior Member
3 years 10 months ago #4150
by walker_tr9
Just to confirm, I did get this figured out.
BTW: ngsolve does "complain" about
definedonbound="Gamma"
not being documented. I suppose it is safe.
Time to create page: 0.197 seconds
