How to serialize BaseMatrix?
3 years 9 months ago #4125
by stf
How to serialize BaseMatrix? was created by stf
Hi all,
NGSolve is a great tool, but I'm having trouble with some details.
I have set up a solver for my PDE, and calculated inverse of system matrix since I'm solving for many different "right-hand sides". Now, for bigger meshes, the calculation of the inverse takes some time and I wanted to store the calculated inverse. However, it seems it's not working like other ngs objects.
Here is the code:
The calculation is working without issues:
To sum it up, how can I save BaseMatrix values to a file (NumPy or any other format)?
Thanks and I whish all of you a happy 2022!
Here is the code:
ainv_filename = f'{self.results_dir}/A_inv.npz'
if os.path.exists(ainv_filename)
self.log(f'Loading inverse of stiffness matrix...')
# Load A_inv
self.a_inv.mat = np.load(ainv_filename) # First self.a_inv should be initialized?
self.log(f'Calculating inverse of stiffness matrix...')
self.a_inv = self.a.mat.Inverse(self.fes.FreeDofs())
np.savez_compressed(ainv_filename, self.a_inv.mat)
# Compute the solution (using precalculated inverse of stifness matrix A)
self.gfu.vec.data = self.a_inv * self.f.vec
3 years 9 months ago #4126
Replied by joachim on topic How to serialize BaseMatrix?
Hi Stefan,
if you can use the in-house SparseCholesky (for symmetric positive definite matrices)
you have pickling support for it.
All the best for 2022 !
inv = mat.Inverse (inverse="sparsecholesky")
3 years 9 months ago #4128
by stf
Replied by stf on topic How to serialize BaseMatrix?
Hi Joachim,
Thank you for replying so promptly!
I've tried this:
but it seems pickling is not supported in my version of NGSolve:
Is this a recently added feature? I've installed NGSolve via Anaconda:
I've tried this:
self.a_inv = self.a.mat.Inverse(self.fes.FreeDofs(), inverse="sparsecholesky")
pickle.dump(self.a_inv, open("a_inv.p", "wb"))
TypeError: cannot pickle 'ngsolve.la.SparseCholesky_d' object
>>> import ngsolve as ngs
>>> ngs.__version__
'6.2.2008'
3 years 9 months ago #4129
by matthiash
Replied by matthiash on topic How to serialize BaseMatrix?
Yes, this feature was added with the latest release (6.2.2105). It is available on anaconda:
anaconda.org/NGSolve/ngsolve
3 years 9 months ago #4131
by stf
Hi Matthiash,
I've updated ngsolve to the latest and now I can pickle SparseCholesky objects.
However, this comes with an excessive memory consumption and script/program crashes (Calculating inverse is already at about 27 GB, and pickling consumes the remaining 5GB on this machine).
Is there a way or advice on how to do it "manually"?
