Is it possible to do Vibroacoustics ?
3 years 11 months ago #4072 by Kai
More precisely i want to know if there is any pitfall for the implementation of something like seen in this elmer fem video.
It would be great if i can use ngsolve for this task :-)
3 years 11 months ago #4073 by joachim
Hi Kai,
I guess you want to solve it in two steps ?
Step 1 eigenvalue problem for the tuning forg.
Step 2 solve the acoustic problem
For step 1 you may watch this video from a student's seminar:
For step 2 you may want to use PML for the radiation condition, see
docu.ngsolve.org/latest/i-tutorials/unit-1.7-helmholtz/pml.html
Best, Joachim
The following user(s) said Thank You: Kai
3 years 6 months ago - 3 years 6 months ago #4315 by Kai
Ok, i have played around with some examples where the wave equation is used. I finally end up with a code that have the boundaries of a rectangle as source for the wave equation.
[code][color=#0033b3]from [/color]ngsolve [color=#0033b3]import [/color]* [color=#0033b3]from [/color]netgen.geom2d [color=#0033b3]import [/color]SplineGeometry [color=#8c8c8c]# Geometry[/color] geo = SplineGeometry() geo.AddCircle(([color=#1750eb]0.0[/color], [color=#1750eb]0.0[/color]), [color=#1750eb]0.8[/color], [color=#660099]bc[/color]=[color=#067d17]"outer"[/color]) geo.AddRectangle((-[color=#1750eb]0.05[/color], -[color=#1750eb]0.025[/color]), ([color=#1750eb]0.025[/color], [color=#1750eb]0.275[/color]), [color=#660099]leftdomain[/color]=[color=#1750eb]0[/color], [color=#660099]rightdomain[/color]=[color=#1750eb]1[/color], [color=#660099]bc[/color]=[color=#067d17]"scat"[/color]) mesh = Mesh(geo.GenerateMesh([color=#660099]maxh[/color]=[color=#1750eb]0.1[/color])) fes = H1(mesh, [color=#660099]order[/color]=[color=#1750eb]5[/color], [color=#660099]complex[/color]=[color=#0033b3]True[/color]) u, v = fes.TnT() [color=#8c8c8c]# Wavenumber & source[/color] omega = [color=#1750eb]15[/color] pulse = [color=#1750eb]5e4[/color]*exp(-([color=#1750eb]40[/color]**[color=#1750eb]2[/color])*((x-[color=#1750eb]0.5[/color])*(x-[color=#1750eb]0.5[/color]) + (y-[color=#1750eb]0.5[/color])*(y-[color=#1750eb]0.5[/color]))) [color=#8c8c8c]# Forms[/color] a = BilinearForm(fes) a += grad(u)*grad(v)*dx - omega**[color=#1750eb]2[/color]*u*v*dx a += -omega*[color=#1750eb]1j[/color]*u*v * ds([color=#067d17]"outer"[/color]) a.Assemble() f = LinearForm(fes) f += [color=#1750eb]1 [/color]* v * ds([color=#067d17]"scat"[/color]) f.Assemble(); gfu = GridFunction(fes, [color=#660099]name[/color]=[color=#067d17]"u"[/color]) gfu.vec.data = a.mat.Inverse() * f.vec Draw(gfu)
[/code]
I now want to use my computed eigen modes for the source geometry, that i compute as
[code]a, b, fes = build_elasticity_system(mesh, steel, dirichlet)  u = ngsolve.GridFunction(fes, multidim=num) lams = ngsolve.ArnoldiSolver(a.mat, b.mat, fes.FreeDofs(), u.vecs, shift)
[/code]
How can i achieve this ?
I further have some problems for the 3D version of all this, i do not really understand how to asign boundary conditions to specific parts of a herachical mesh. My code so far to generate the acoustic structure mesh is
[code]import ngsolve from ngsolve import * from netgen.stl import * from netgen.csg import * from netgen.meshing import * geo2 = STLGeometry("../test_data/tuningfork.stl") m2 = geo2.GenerateMesh() centerx = 0 centery = 0 centerz = 0 count = 0 for e in m2.Elements2D():     for v in e.vertices:             centerx = centerx + m2[v][0]             centery = centery + m2[v][1]             centerz = centerz + m2[v][2]             count = count + 1 centerx = centerx / count centery = centery / count centerz = centerz / count R = 0 for e in m2.Elements2D():     for v in e.vertices:             x = -centerx + m2[v][0]             y = -centery + m2[v][1]             z = -centerz + m2[v][2]             tmp = sqrt(x*x + y*y + z*z)             if tmp > R:                 R = tmp print("R : " + str(R)) geo1 = CSGeometry() # Set the mesh size on the sphere surface to 0.1 sphere = Sphere(Pnt(centerx, centery, centerz), 2.5*R) geo1.Add(sphere) m1 = geo1.GenerateMesh() print(m2) # create an empty mesh mesh = netgen.meshing.Mesh() # a face-descriptor stores properties associated with a set of surface elements # bc .. boundary condition marker, # domin/domout .. domain-number in front/back of surface elements (0 = void), # surfnr .. number of the surface described by the face-descriptor fd_outside = mesh.Add(FaceDescriptor(bc=1,domin=1,surfnr=1)) fd_inside = mesh.Add(FaceDescriptor(bc=2,domin=2,domout=1,surfnr=2)) # copy all boundary points from first mesh to new mesh. # pmap1 maps point-numbers from old to new mesh pmap1 = {} for e in m1.Elements2D():     for v in e.vertices:         if v not in pmap1:             pmap1[v] = mesh.Add (m1[v]) # copy surface elements from first mesh to new mesh # we have to map point-numbers: for e in m1.Elements2D():     mesh.Add(Element2D(fd_outside, [pmap1[v] for v in e.vertices])) # same for the second mesh: pmap2 = {} for e in m2.Elements2D():     for v in e.vertices:         if v not in pmap2:             pmap2[v] = mesh.Add(m2[v]) n = len(pmap2) for e in m2.Elements2D():     mesh.Add(Element2D(fd_inside, [pmap2[v] for v in e.vertices])) mesh.GenerateVolumeMesh(maxh=10.0) mesh.Save("acousticmesh.vol") mesh = ngsolve.Mesh(mesh)
[/code] So i would be very happy if some one could give me some hints to put this all together :-)
Last edit: 3 years 6 months ago by Kai.
3 years 6 months ago #4316 by Kai
hm ... my code is not visible in firefox ...
3 years 6 months ago - 3 years 6 months ago #4317 by Kai
ok -repost for check if i had made a formating mistake
# Geometry
geo.AddCircle((0.0, 0.0), 0.8, bc="outer")
geo.AddRectangle((-0.05, -0.025), (0.025, 0.275),
leftdomain=0, rightdomain=1, bc="scat")
fes = H1(mesh, order=5, complex=True)
u, v = fes.TnT()
omega = 15
pulse = 5e4*exp(-(40**2)*((x-0.5)*(x-0.5) + (y-0.5)*(y-0.5)))
# Forms
a += grad(u)*grad(v)*dx - omega**2*u*v*dx
a += -omega*1j*u*v * ds("outer")
f += 1 * v * ds("scat")
f.Assemble();
gfu = GridFunction(fes, name="u")
Draw(gfu)
import ngsolve
centerx = 0
centery = 0
centerz = 0
count = 0
            count = count + 1
R = 0
            if tmp > R:
                R = tmp
geo1 = CSGeometry()
geo1.Add(sphere)
print(m2)
pmap1 = {}
        if v not in pmap1:
pmap2 = {}
        if v not in pmap2:
n = len(pmap2)
3 years 6 months ago #4318 by Kai
looks like the [code] tag does not work
