Solve Surface PDE on stl geometry with boundary
3 years 10 months ago #4060 by Kai
Hi all :)
i like to do the surface pde example but with a geometry that comes from some stl file.
is this possible ?
i would be happy if some one could tell me :)
3 years 10 months ago - 3 years 10 months ago #4061 by Kai
I have now combined the surface pde example with the, manual mesh generation example, i think thats a good startingpoint but i do not know how to set dirichlet bnd conditions, would be great if some one can help me :).
I get in the console "used dof inconsistency" ... if i run the following code ...
from ngsolve import * from netgen.csg import * from netgen.geom2d import unit_square from ngsolve import Draw ngmesh = netgen.meshing.Mesh(dim=2) N=5 pnums = [] for i in range(N + 1): for j in range(N + 1): pnums.append(ngmesh.Add(netgen.meshing.MeshPoint(Pnt(i / N, j / N, 0)))) idx_dom = ngmesh.AddRegion("mat", dim=2) for j in range(N): for i in range(N): ngmesh.Add(netgen.meshing.Element2D(idx_dom, [pnums[i + j * (N + 1)], pnums[i + (j + 1) * (N + 1)], pnums[i + 1 + (j + 1) * (N + 1)], pnums[i + 1 + j * (N + 1)]])) # horizontal boundaries for i in range(N): ngmesh.Add(netgen.meshing.Element1D([pnums[N + i * (N + 1)], pnums[N + (i + 1) * (N + 1)]], index=1)) ngmesh.Add(netgen.meshing.Element1D([pnums[0 + i * (N + 1)], pnums[0 + (i + 1) * (N + 1)]], index=1)) # vertical boundaries for i in range(N): ngmesh.Add(netgen.meshing.Element1D([pnums[i], pnums[i + 1]], index=2)) ngmesh.Add(netgen.meshing.Element1D([pnums[i + N * (N + 1)], pnums[i + 1 + N * (N + 1)]], index=2)) mesh = Mesh(ngmesh) Draw(mesh) # geo = CSGeometry() # sphere = Sphere(Pnt(0,0,0), 1) # bot = Plane(Pnt(0,0,0), Vec(0,0,-1)) # finitesphere = sphere * bot # # geo.AddSurface(sphere, finitesphere.bc("surface")) # geo.NameEdge(sphere,bot, "bottom") # # mesh = Mesh(geo.GenerateMesh(maxh=0.3)) # mesh.Curve(2) # Draw(mesh) # fes = H1(mesh, order=2, dirichlet=[1, 2]) u, v = fes.TnT() print(fes.FreeDofs()) a = BilinearForm(fes, symmetric=True) a += grad(u).Trace()*grad(v).Trace()*ds a.Assemble() force = 1.0 f = LinearForm(fes) f += force*v*ds f.Assemble() gfu = GridFunction(fes) gfu.vec.data = a.mat.Inverse(fes.FreeDofs())*f.vec Draw(gfu, mesh, "u")
Last edit: 3 years 10 months ago by Kai.
3 years 10 months ago #4062 by mneunteufel
Hi Kai,
with ngmesh = netgen.meshing.Mesh(dim=2) you are creating a 2D mesh, not a surface mesh in 3D.
Thus, with a += grad(u).Trace()*grad(v).Trace()*ds you are integrating only over the four edges. This gives the used_dof_inconsistence warning.
I changed/added the following lines, compare attached file, to get the desired result. As stated in the surface pde tutorial you need the keyword dirichlet_bbnd instead of dirichlet to set Dirichlet boundary conditions for surface PDEs.
ngmesh = netgen.meshing.Mesh(dim=3) # to access edges easier ngmesh.SetCD2Name(1, "top_bot") ngmesh.SetCD2Name(2, "left_right") fes = H1(mesh, order=2, dirichlet_bbnd="top_bot|left_right")
File Attachment:
File Name: surface_pde.py
File Size:2 KB
