Complex conjugates of test functions
4 years 8 hours ago #4044 by Ben_Latham
I'm working on implementing a DtN method for a problem involving complex waves. Is it the case that if you have lines like:
fes = H1(mesh, order, complex=True) u,v=fes.TnT()
then ngsolve will read all instances of v as Conj(v)? Or will I need to manually write Conj(v) in my weak form? If the former, and I want to create a matrix with elements which do not have a conjugate, can I use Conj(v) to get these? Any clarification on this point would be helpful.
Ben
3 years 11 months ago #4045 by christopher
the basis functions are always real, even in a complex space. Just the coefficients are complex. Therefore you can just use v.
