translate python grad(u).trans code to C++
3 years 10 months ago #4017 by Kai
Hi all :),
i try to translate the following piece of python code
self.u = self.fes.TrialFunction() self.v = self.fes.TestFunction() # StiffnessMatrix depending on material type: if (self.material.type == "linear"): self.A = BilinearForm(self.fes) self.A += 2 * self.material.mu * InnerProduct(1 / 2 * (grad(self.u) + grad(self.u).trans), 1 / 2 * (grad(self.v) + grad(self.v).trans)) * dx
into corresponding C++ code so far i have
ngcomp::ProxyNode u = fes->GetTrialFunction(); ngcomp::ProxyNode v = fes->GetTestFunction(); Flags flags_bfa; std::shared_ptr<T_BilinearFormSymmetric<double>> bfa = make_shared<T_BilinearFormSymmetric<double>> (fes, "a", flags_bfa); bfa->AddIntegrator(make_shared<SymbolicBilinearFormIntegrator>( material.mu * InnerProduct( 0.5f*(u->Deriv() + TransposeCF(u->Deriv())), 0.5f*(v->Deriv() + TransposeCF(v->Deriv()))), VOL, VOL));
but the TransposeCF leads to
terminate called after throwing an instance of 'ngcore::Exception' what(): Transpose of non-matrix called 00:46:50: Das Programm ist abgestürzt.
So my question is how can i transpose v->Deriv() and u->Deriv() ?
Thank you for any help :)
3 years 10 months ago #4019 by joachim
Hi Kai,
can you show us how you created the finite element space fes ? Is it really vector-valued ?
For debugging, you can insert a
cout << *(u->Deriv()) << endl;
before the exception is thrown.
3 years 10 months ago #4020 by Kai
Hi Joachim,
thanks for quick response, i used the wrong FESpace. Now iam using VectorH1FESpace but the next problem follows : the SymbolicBilinearFormIntegrator does not work with Vector valued Coefficient functions ...
hope this is ok to attach my new qustion here in this thread ?
3 years 10 months ago #4021 by joachim
yes, at the end you need a scalar-valued function for the SymbolicBilinearFormIntegrator.
You get it, for example, by taking InnerProduct(grad(u), grad(v)).
grad(u) and grad(v) are matrix-valued.
3 years 10 months ago #4022 by Kai
But i do already the InnerProduct like InnerProdukt(grad(u) + Transpose(grad(u)), grad(v) + Transpose(grad(v)))
but this returns a coef innerproduct, fix size = 9, real ... i do not see whats wrong here ... mathematically this should work ?
3 years 10 months ago #4023 by joachim
can you do a
auto func = material.mu * InnerProduct( 0.5f*(u->Deriv() + TransposeCF(u->Deriv())), 0.5f*(v->Deriv() + TransposeCF(v->Deriv()))); cout << *func << endl;
and send the output ?
If this does not help, you may send the complete example.
