Build on Windows - CMAKE Error
4 years 2 weeks ago #3987 by joey
i would like to use NGSolve with Windows 10 and am trying to build it from sources (because i want to use MPI/PETSc).
Unfortunately cmake cant find the METIS-package (but is is installed).
Would you guys have an idea for solving this?
Thanks,
joey
File Attachment:
File Name: error_miss...etis.txt
File Size:3 KB
4 years 2 weeks ago #3989 by christopher
Are you sure you want to use windows for this?
This comes on the petsc documentation if you search for installing on windows:
Installing PETSc On Microsoft Windows
Are You Sure?
Are you sure you want to use Microsoft Windows? We recommend using Linux if possible (and minimize troubleshooting Microsoft Windows related issues).
I had once a mpi - windows NGSolve installation running (without petsc), but it needed quite some adaptations and was quite some work.... If you are sure you want to go through this I can search for my modifications... But I would recommend using linux.
4 years 1 week ago #4011 by joey
Replied by joey on topic Build on Windows - CMAKE Error
Hi Christopher,
thanks for the advice!
I installed ngsolve now on the linux subsystem of windows (wsl version 2 with ubuntu 18.04) and this works :)
best regards,
joey
