Compound space on different meshes
4 years 1 month ago #3966
by janfp
Compound space on different meshes was created by janfp
Dear all,
to simulate a PDE-ODE-System, I was trying to use a compound FE-Space on two different mesh, one with only one DOF (for the ODE). However, it seems that assembling in such a space does not work properly.
Is this a bug or am I using it in an unintended way?
Minimal example:
Minimal example:
from ngsolve.meshes import Make1DMesh
from ngsolve.meshes import Mesh as NgMesh
from netgen.meshing import *
nx = 10
ngsmesh = Make1DMesh(nx)
ngsmesh_ODE = Make1DMesh(1) # For the ODE, thus only one DOF
fes1 = L2(ngsmesh_ODE, order=0)
fes2 = L2(ngsmesh, order=1, dgjumps=True)
fes = FESpace([fes1,fes2])
m = BilinearForm(fes)
m.components[0] += BFI("mass", coef=1) #u[0]*v[0]*dx
m.components[1] += BFI("mass", coef=1) #u[1]*v[1]*dx
print(m.mat)
4 years 1 month ago #3967
Replied by joachim on topic Compound space on different meshes
The component-spaces of a compound space have to live on the same mesh.
You can use NumberFESpace instead. It is one constant function on the whole domain.
The following user(s) said Thank You: janfp
4 years 1 month ago - 4 years 1 month ago #3968
Replied by christopher on topic Compound space on different meshes
Compound spaces expect the same mesh to be defined on. But you can use a global space with one dof by using the NumberSpace:
fes1 = NumberSpace(ngsmesh)
fes = fes1 * fes2
(uO, u), (vO, v) = fes.TnT()
m += uO * vO * dx
m += u * v * dx
print(m.mat)
Last edit: 4 years 1 month ago by christopher.
