how do you have multiple boundaries with different conditions.
4 years 1 month ago #3928
by place
i am trying to apply different boundary conditions to different boundaries, but the first stops working when i add the second, as thought its getting overwritten.
# parabolic inflow
uin1 = CoefficientFunction((-1.5*4*(0-y)*(.41-y)/(.41*.41),0))
gfu.components[0].Set(uin1, definedon=mesh.Boundaries("inlet1"))
uin2 = CoefficientFunction((-1.5*4*(1-y)*(1.41-y)/(.41*.41),0))
gfu.components[0].Set(uin2, definedon=mesh.Boundaries("inlet2"))
4 years 1 month ago #3930
Replied by christopher on topic how do you have multiple boundaries with different conditions.
This behaviour is explained here in the documentation:
docu.ngsolve.org/latest/i-tutorials/unit...domains.html#Pitfall !
In short, you have to set them in one .Set call by using a domain (boundary-) wise coefficientfunction:
gfu.components[0].Set(mesh.BoundaryCF({ "inlet1" : uin1, "inlet2" : uin2}), definedon=mesh.Boundaries("inlet1|inlet2"))
The following user(s) said Thank You: place
4 years 1 month ago #3931
by place
Replied by place on topic how do you have multiple boundaries with different conditions.
thanks
cut/paste straight in and working.
guessed it was something like that, but didn't find it, i'll check that doc.
4 years 4 weeks ago - 4 years 1 week ago #3980
by place
is there a resource for other boundary NS conditions?
* fixed pressure boundary.
* no perpendicular flow. (symmetry)
* infinite (no returning information cf perfectly matching)
all the examples i see are for velocity, i made a guess as to how to do some of these, but no good.
can you help again?
FYI: i want to add a boundary with the pressure from another boundary, somewhere else, in the same model. to approximate a small 'bleed' pipe without the massive simulation cost.
i guess it could (best) be done by just joining the remote geometries, but then i can only really guess how to do that, or even how that's referred to, so i could search for information.
can you help again?
Last edit: 4 years 1 week ago by place.
Time to create page: 0.187 seconds
