Can the NGSolve provide other file forms for output data expect ".vtk"?
4 years 2 months ago #3920
by Younghigh
Dear all,
I have obtained a set of data including discrete velocity and pressure from solving the Navier-Stokes equations. I know only how to output them by a vtk file, which cannot work on Tecplot. So, there are other file forms, like .dat, .plt., which can applied on Tecplot? If yes, what are their commands?
PS: the following is an example of outputing discrete data:
Kind regards,
Di Yang
vel = gfu.components[0]
vtk = VTKOutput(ma=mesh, coefs=[vel], names=["velocity"],\
filename="velocity", subdivision=2)
vtk.Do()
Kind regards,
Di Yang
4 years 2 months ago #3921
by hvwahl
Replied by hvwahl on topic Can the NGSolve provide other file forms for output data expect ".vtk"?
Hi Di Yang,
unless you initialise the VTKOutput with legacy=True, VTU files will now be written (if you have a relatively new version of NGSolve), which I believe tecplot can open.
Best wishes,
Henry
Best wishes,
Henry
4 years 2 months ago #3922
by Younghigh
Replied by Younghigh on topic Can the NGSolve provide other file forms for output data expect ".vtk"?
Hi Henry,
Thank you for your reply. I have no idea of initialising the VTKOutput with legacy=True. What is the command in detail? Because the following command
is not correct.
Di Yang
vtk = VTKOutput(legacy=True, ma=mesh, coefs=[v100], names=["v100"],\
vtk.Do()
Di Yang
4 years 2 months ago #3923
by hvwahl
Hi Di Yang,
in principle
is correct. Adding the legacy=True argument will write vtk files (rather than vtu). However, the vtu output is very new! You need a nightly build of NGSolve or build from the current master branch, as this update to the VTKOutput was introduced after the release of v6.2.2004.
Best wishes,
Henry
in principle
vtk = VTKOutput(ma=mesh, coefs=[v100], names=["v100"],
vtk.Do()
Best wishes,
Henry
4 years 2 months ago #3924
by Younghigh
Hi Henry,
In Paraview, vtk files can be tranformed into vtu files. Thank u.
Di
Di
Time to create page: 0.164 seconds
