L2 projection
4 years 2 months ago - 4 years 2 months ago #3897 by Macs
L2 projection was created by Macs
Dear NGSpy Team,
I was just testing my L2 projection, projecting uref=x2 on a finite element space V consisting of linear polynomials, but somehow the error (Pu-u,Pu) is not zero, but of order 10^-6.
Here is my code:
uref = CoefficientFunction(x*x) mesh = Mesh(unit_square.GenerateMesh(maxh=0.1)) V = L2(mesh, order=1) u = V.TrialFunction() v = V.TestFunction() L = LinearForm(V) L += uref * v * dx a = BilinearForm(V, symmetric=True) a += u*v*dx Puref = GridFunction(V) a.Assemble() L.Assemble() Puref.vec.data = a.mat.Inverse(V.FreeDofs(), inverse='sparsecholesky') * L.vec print(Integrate((uref-Puref)*Puref, mesh))
Could you point me out to what is wrong?
Thank you!
Last edit: 4 years 2 months ago by Macs.
4 years 2 months ago #3898 by Guosheng Fu
Replied by Guosheng Fu on topic L2 projection
I think the default integration rule for Integrate is 5.
You can try this to get close to machine precision error:
print(Integrate((uref-Puref)*Puref, mesh, order=2))
4 years 2 months ago #3899 by sneidehx
Replied by sneidehx on topic L2 projection
Hey together,
I think the problem is not the machine precision error.
If [tex]\Pi_k[/tex] is the L2 Projection, then
the following should hold:
[tex](\Pi_k u - u, v_h) = 0 \quad \forall v_h \in P^k(\mathcal T) .[/tex]
This should be true for any Integration formula with algebraic exactness higher than k.
I suspect something in the Integration step.
4 years 2 months ago #3900 by joachim
Replied by joachim on topic L2 projection
The linear-form is integrated with twice the order of the finite elements. So an integration order of 2 is used, but order 3 would be needed.
Giving some bonus-order as
L += uref * v * dx(bonus_intorder=1)
gives you the result at machine precision.
The following user(s) said Thank You: Macs, sneidehx
4 years 2 months ago #3901 by Macs
Replied by Macs on topic L2 projection
Thank you!
