Different versions - different meshing?
4 years 3 months ago - 4 years 3 months ago #3884
by nepomuk
Different versions - different meshing? was created by nepomuk
Is it possible, that the meshing changed throughout the versions of NGSolve? With the code below, I got a mesh with 12543 nodes in NGSolve-6.2.2101 and with 12457 nodes in the in NGSolve-6.2.2103. That's a problem, because I saved some GridFunctions with the old version, that I want to process with the latest version. Is there a fix? Can I somehow create both meshes in one version?
BR, Nepomuk
BR, Nepomuk
Lbeam = SplineGeometry()
rad=0.25
offset=0.1
mh=0.025
pnts = [(0, 0), (2.5, 0), (2.5, 1), (1+rad+offset,1),(1+rad+offset,1-rad+offset),(1+offset,1-rad+offset),(1-rad+offset,1-rad+offset),(1-rad+offset,1+offset),(1-rad+offset,1+rad+offset),(1,1+rad+offset),(1,2.5),(0,2.5),(1,1)]
pind = [ Lbeam.AppendPoint(*pnt) for pnt in pnts ]
Lbeam.Append(['line',pind[0],pind[1]],leftdomain=1,rightdomain=0,bc="bottom")
Lbeam.Append(['line',pind[1],pind[2]],leftdomain=1,rightdomain=0,bc="force")
Lbeam.Append(['line',pind[2],pind[3]],leftdomain=1,rightdomain=0,bc="nix")
Lbeam.Append(['spline3',pind[3],pind[4],pind[5]],leftdomain=1,rightdomain=2,bc="nix")
Lbeam.Append(['spline3',pind[5],pind[6],pind[7]],leftdomain=1,rightdomain=2,bc="nix")
Lbeam.Append(['spline3',pind[7],pind[8],pind[9]],leftdomain=1,rightdomain=2,bc="nix")
Lbeam.Append(['line',pind[9],pind[10]],leftdomain=1,rightdomain=0,bc="nix")
Lbeam.Append(['line',pind[10],pind[11]],leftdomain=1,rightdomain=0,bc="diri")
Lbeam.Append(['line',pind[11],pind[0]],leftdomain=1,rightdomain=0,bc="left")
Lbeam.Append(['line',pind[3],pind[12]],leftdomain=2,rightdomain=0,bc="nix")
Lbeam.Append(['line',pind[12],pind[9]],leftdomain=2,rightdomain=0,bc="nix")
Lbeam.SetDomainMaxH(2, mh*0.2)
Last edit: 4 years 3 months ago by nepomuk.
4 years 3 months ago #3886
Replied by christopher on topic Different versions - different meshing?
Hi, yes we improved quite a bit of stuff in the mesher. You need to save the mesh with the old version along with the gridfunction. The mesh can then be loaded with the new version.
Best Christopher
Best Christopher
Time to create page: 0.171 seconds
