- Thank you received: 3
Original edges retained after mesh.Refine()
4 years 5 months ago #3811
by ddrake
Original edges retained after mesh.Refine() was created by ddrake
If we generate a mesh like this:
The count and collection of edges returned by mesh.nedge and mesh.edges are correct:
13
{E0: (V0, V4), E1: (V0, V7), E2: (V1, V4), E3: (V1, V5), E4: (V2, V5), E5: (V2, V6), E6: (V3, V6),
E7: (V3, V7), E8: (V4, V5), E9: (V4, V6), E10: (V4, V7), E11: (V5, V6), E12: (V6, V7)}
If we then refine the mesh
The count and collection of edges returned by mesh.nedge and mesh.edges are now incorrect:
57 (should be 44)
E7: (V3, V7), E8: (V4, V5), E9: (V4, V6), E10: (V4, V7), E11: (V5, V6), E12: (V6, V7),
E13: (V0, V8), E14: (V0, V13), E15: (V0, V17), E16: (V1, V9), E17: (V1, V14), E18: (V1, V18),
E19: (V2, V10), E20: (V2, V15), E21: (V2, V19), E22: (V3, V11), E23: (V3, V16), E24: (V3, V20),
E25: (V4, V8), E26: (V4, V9), E27: (V4, V12), E28: (V4, V13), E29: (V4, V18), E30: (V5, V9),
E31: (V5, V10), E32: (V5, V12), E33: (V5, V14), E34: (V5, V19), E35: (V6, V10), E36: (V6, V11),
E37: (V6, V12), E38: (V6, V15), E39: (V6, V20), E40: (V7, V8), E41: (V7, V11), E42: (V7, V12),
E43: (V7, V16), E44: (V7, V17), E45: (V8, V12), E46: (V8, V13), E47: (V8, V17), E48: (V9, V12),
E49: (V9, V14), E50: (V9, V18), E51: (V10, V12), E52: (V10, V15), E53: (V10, V19),
E54: (V11, V12), E55: (V11, V16), E56: (V11, V20)}
The first 13 reported edges are not valid edges in the refined mesh. They are simply the 13 edges of the original mesh carried over into the refined mesh. We can verify this by checking the edges associated with vertex V0. Note that the edges property of a vertex includes opposite edges in addition to the edges incident on the vertex.
(E13, E14, E15, E46, E47)
This is the correct collection of edges associated with vertex V0. Note that it does not contain E0 and E1 as reported by mesh.edges.
Looking at the Python bindings, the topology is updated after the mesh is refined, but the code to perform the update is complicated. I'm attaching a notebook that reproduces this issue.
Thanks!
Dow
from ngsolve import Mesh
mesh = Mesh(unit_square.GenerateMesh(maxh=.5))
print(mesh.nedge)
ed = {e: mesh[e].vertices for e in mesh.edges}
ed
print(mesh.nedge)
ed
v0 = mesh[NodeId(VERTEX, 0)]
v0.edges
Thanks!
Dow
4 years 5 months ago #3812
by ddrake
Replied by ddrake on topic Original edges retained after mesh.Refine()
Since the topology is being updated correctly for vertices, we can work around the issue like this:
44
[E13, E14, E15, E16, E17, E18, E19, E20, E21, E22, E23, E24, E25, E26, E27, E28, E29, E30, E31, E32, E33, E34, E35, E36, E37, E38, E39, E40, E41, E42, E43, E44, E45, E46, E47, E48, E49, E50, E51, E52, E53, E54, E55, E56]
true_edges = sorted(list(set(e for v in mesh.vertices
for e in mesh[v].edges)), key=lambda e: e.nr)
print(len(true_edges))
print(true_edges)
4 years 4 months ago #3814
by aymgoa
The AYM Yoga School's 200/300hr Teacher Training is a unique journey for those who are interested in specializing in yoga for all ages, from pre-conception to seniors.
Learn more: yogateachertraininggoa.com/
Replied by aymgoa on topic Original edges retained after mesh.Refine()
noted.. thank you
4 years 4 months ago #3815
Replied by joachim on topic Original edges retained after mesh.Refine()
The coarse edges are kept on purpose, they are used in H(curl) multigrid.
To figure out the active edges, you can define an H(curl, order=0) - space, and ask for the FreeDofs - Array.
Since these inactive edges (and faces) have let to confusion before, we are thinking of making them optional.
4 years 4 months ago #3818
by ddrake
Thanks, Joachim!
Your solution is more efficient.
For a mesh with 743K vertices, this took 3.6 seconds vs. 11.0 seconds for the solution I posted earlier.
Dow
Z = HCurl(mesh, order=0)
fd = Z.FreeDofs()
true_edges = [e for i, e in enumerate(mesh.edges) if fd[i]]
Dow
Time to create page: 0.178 seconds
