Install NGSolve from the source on Windows Subsystem for Linux
4 years 4 months ago #3807 by braket
I am trying to install NGSolve on Windows Subsystem for Linux ( WSL ). I have strictly followed the guide to build from the source onto Debian/ Ubuntu on WSL with using a Debian/Ubuntu terminal on Windows 10. However, I am not able to run any python script in the python_tutorial file after the NGSolve is successfully installed. The message always shows up "Segmentation fault". For a detailed example, it shows:
NETGEN-6.2.2103-30-g44d72073 Developed by Joachim Schoeberl at 2010-xxxx Vienna University of Technology 2006-2010 RWTH Aachen University 1996-2006 Johannes Kepler University Linz Problem in Tk_Init: result = no display name and no $DISPLAY environment variable optfile ./ng.opt does not exist - using default values togl-version : 2 no OpenGL loading ngsolve library NGSolve-6.2.2103-23-g27f2b0149 Using Lapack Including sparse direct solver UMFPACK Running parallel using 8 thread(s) importing NGSolve-6.2.2103-23-g27f2b0149 (should) load python file 'mesh.py' loading ngsolve library NGSolve-6.2.2103-23-g27f2b0149 Using Lapack Including sparse direct solver UMFPACK Running parallel using 8 thread(s) Segmentation fault
I have checked that my python version is 3.7.3 in the Debian/Ubuntu on WSL terminal environment. On the other hand, everything works well with the Windows installer on my Windows 10 laptop. So I am wondering if NGSolve does not support to be built from the source on WSL environment yet. Does anyone have experience in working with WSL and how to solve the problem?
4 years 3 months ago #3842 by place
Possibly of interest;
i'm doing something similar, using same version of Ubuntu libs, setting up on an unsupported Linux disto.
initially i got this....
Problem in Tk_Init:
result = unknown color name "BACKGROUND"
togl-version : 2
no OpenGL
fixed by searching for TK issues and found this fix...
xrdb -load /dev/null
xrdb -query
not sure why and isn't the same for you, but maybe same technique will work.
