How can I output results on surface meshes to vtk file?
4 years 4 months ago - 4 years 4 months ago #3787
by yzz
How can I output results on surface meshes to vtk file? was created by yzz
Recently, I am solving some problems on surfaces with ngsolve. I am wondering if it can output the results to file for surface domains.
The vtk file output by the following code is almost empty. Are the parameters for Vtkoutput wrong?
# from ngsolve.webgui import Draw
geo.Add(Sphere(Pnt(0,0,0),1))
mesh = Mesh(geo.GenerateMesh(maxh=0.5, perfstepsend=MeshingStep.MESHSURFACE))
V_HS = HDivSurface(mesh)
u = GridFunction(V_HS)
vtk = VTKOutput(ma=mesh,coefs=[u],names=["sol"],filename="data/hdiv")
for i in range(u.space.ndof):
u.vec[:] = 0
u.vec[i] = 1
vtk.Do()
Last edit: 4 years 4 months ago by yzz.
4 years 4 months ago #3790
by schruste
Replied by schruste on topic How can I output results on surface meshes to vtk file?
just use Do(BND) instead of Do() and only the surface mesh will be treated.
