Add Matrix to SymbolicBFI
4 years 3 months ago #3772 by creativeworker
is there any possibility to add a constant Matrix to the Bilinear Form?
a = BilinearForm(fes) a+= SymbolicBFI(weak_K(u,v)) a+= "const. Matrix from Numpy" #either here a.Assemble() a.mat += "const Matrix form Numpy" # or here (but does then a.AssembleLinearization() work later?)
The benefit would be that I can still use a.Apply, a.AssembleLinearization, etc... as I would with only considering the "analytical, continous" weak form of my problem.
Thanks for your help in advance!
4 years 3 months ago #3782 by christopher
One should be able to create a scipy sparse matrix like here:
docu.ngsolve.org/latest/i-tutorials/unit...ighlight=scipy%20csr
and if copy=False argument is set, one should be able to manipulate the underlying c++ matrix. But not 100% sure if no copy is involved so please check!
