element-wise generalized eigenvalue problem in X-FEM
4 years 5 months ago - 4 years 5 months ago #3766
by Shaoqi
element-wise generalized eigenvalue problem in X-FEM was created by Shaoqi
[attachment=undefined]eigen_prob.png[/attachment]Hi ngsolve comminity,
I would like to calculate the element-wise eigenvalue k of an generalized eigenvalue problem in the case "CufFEM" or X-FEM.
The problem is stated as:
Am x=ke,mBmx
where the matrix A and B is written as attached figure
Could you give some instruction on implementing this problem, I tried something to calculte the integrator like:
I am not sure if I do this with function Integrate or with symbolic integrators
Then with the computed integrator, How can we calculate the eigenvalue problem? I saw some demos which use the algrhitome like PINVIT?
Am x=ke,mBmx
lsPOS = {"levelset": levelset, "domain_type": POS}
lsNEG = {"levelset": levelset, "domain_type": NEG}
lsIF = {"levelset": levelset, "domain_type": IF}
space_flux = HDiv(mesh, order=2)
f = GridFunction(space_flux, "flux")
flux = grad(f)
#intf = Integrate(lsPOS, mesh=mesh, cf=flux, element_wise=True)
intf = Integrate(lsNEG, mesh=mesh, cf=flux, element_wise=True)
intf = Integrate(lsIF, mesh=mesh, cf=flux, element_wise=True)
intf = Integrate(flux, mesh, VOL, element_wise=True)
Attachment not found
Last edit: 4 years 5 months ago by Shaoqi. Reason: add image
4 years 5 months ago #3767
by schruste
Replied by schruste on topic element-wise generalized eigenvalue problem in X-FEM
I cannot see the picture, i.e. I don't know the eigenvalue problem that you want to solve, yet.
4 years 5 months ago - 4 years 5 months ago #3768
by Shaoqi
Replied by Shaoqi on topic element-wise generalized eigenvalue problem in X-FEM
4 years 5 months ago - 4 years 5 months ago #3769
by Shaoqi
Hi Christoph,
Here is the picture
Shaoqi
Here is the picture
Shaoqi
4 years 5 months ago - 4 years 5 months ago #3770
by Shaoqi
The integrations are defined on the levelset interface elements and the entire elements respectively.
Thanks Christoph!
Thanks Christoph!
4 years 5 months ago #3771
by schruste
Hi Shaoqi,
You should setup the matrices A_m and B_m as you would do for solving a PDE problem. Hence, use symoblic integrators or differential symbols to describe the two bilinear forms and assemble the matrices
Afterwards you can use pinvit as done in the i-tutorials (e.g. 2.4.1) to compute the eigenvalues.
