error of view for vtk file
4 years 3 months ago #3764
by Younghigh
error of view for vtk file was created by Younghigh
Dear all,
For viewing the DG solution in Paraview, we firstly run the following codes to get the solution "gfu".
Then we run the following code to get a vtk file "solution",
But when we view this vtk file on Paraview, it is a totally bad file and we cannot see anything. Please tell us where something is wrong.
Di Yang
mesh = Mesh(unit_square.GenerateMesh(maxh=0.3))
order=4
fes = L2(mesh, order=order, dgjumps=True)
jump_u = u-u.Other()
jump_v = v-v.Other()
alpha = 4
diffusion = grad(u)*grad(v) * dx \
+alpha*order**2/h*jump_u*jump_v * dx(skeleton=True) \
+(-mean_dudn*jump_v-mean_dvdn*jump_u) * dx(skeleton=True) \
+alpha*order**2/h*u*v * ds(skeleton=True) \
+(-n*grad(u)*v-n*grad(v)*u)* ds(skeleton=True)
a += diffusion
f += 1*v*dx
gfu = GridFunction(fes, name="uDG")
vtk = VTKOutput(ma=mesh, coefs=[gfu], names=["uh"], filename="solution", subdivision=3)
vtk.Do()
Di Yang
4 years 3 months ago #3765
by schruste
Replied by schruste on topic error of view for vtk file
Dear Di Yang,
Your code snippet is fine. I cannot reproduce a problem. Could you please attach the resulting vtk file so that I can check if it is a problem of the export or a problem on the import side of things?
