complex-valued problem in XFEM
4 years 5 months ago #3752 by hvwahl
Hi Shaoqi,
code like
GetFacetsWithNeighborTypes(mesh, a=ci.GetElementsOfType(HASNEG), b=ci.GetElementsOfType(IF))
is used to mark element boundaries (facets) based on elements cut by the level set in the entire mesh for ghost-penalty stabilisation, which is then done over the entire marked facet.
Best wishes,
Henry
4 years 5 months ago #3753 by hvwahl
As a side note: If all you need is to define integrators on fixed parts of the boundary, another solution would be to define the split in the geometry, so that this is discretised by the mesh.
File Attachment:
File Name: split_boundary.py
File Size:1 KB
The following user(s) said Thank You: Shaoqi
4 years 5 months ago #3754 by Shaoqi
Many thanks! Yes, that could be a solution, but kind of manually.
Cause we have a geometry cut by the interface defined with the level set, it is better we can get the boundaries' info of the "new" geometry directly.
In other words, the geometry could be split automatically once we create the levelset domain.
