Spline geometry singularities
4 years 6 months ago - 4 years 6 months ago #3735 by JBalis
I am performing shape optimization with Netgen in C++ with the SplineSeg3 class and I am wondering if there is a way to elegantly determine the "singularities" of a geometry, i.e. the points where the spline geometry is not C1 continuous.
For instance, in a square domain as the one that I attach to my post, is there a straightforward way to identify the 4 corner points? Or do I need to identify them manually?
Right now, I use a "hack" where I check if the tangential direction to the spline geometry is the same at the left and at the right of a given geometry point but this is not really elegant nor straightforward.
Thank you for your help,
Last edit: 4 years 6 months ago by JBalis.
