run netgen in parallel in python
4 years 5 months ago - 4 years 5 months ago #3730 by gen
First, I like to thank those who made Netgen available to the public. I tried many other meshing softwares, and Netgen is the only one that works perfectly for my applications. Great work!
While Netgen works well, I like to explore its parallel meshing, as currently it takes about 300s to mesh my object (from stl file). My system is Win10, 4-core I7, and I installed Netgen GUI. In the meshing options, the 'parallel" is checked. In my work I actually use Anaconda/Spyder. The following code with `ngcore.TaskManager()' works fine, but the time it costs is not much different from the regular code without `ngcore.TaskManager()'. I was wondering if I am doing it correctly?
I tried running is Spyder, and also on command line by `python test.py`. The results are the same. I have zero knowledge of parallel computing, and would appreciate your insights!
import netgen.stl as stl from netgen.meshing import MeshingStep, MeshingParameters, meshsize, FaceDescriptor from ngsolve import ngsglobals import pyngcore as ngcore #netgen parallel, optional import time ngsglobals.msg_level = 2 geo = stl.STLGeometry("test.stl") start_time = time.time() ngcore.SetNumThreads(4) with ngcore.TaskManager(): # I also tried without this ngcore, the results are the same mesh = geo.GenerateMesh(meshsize.very_coarse, perfstepsstart=MeshingStep.ANALYSE, perfstepsend=MeshingStep.MESHVOLUME, curvaturesafety=5) end_time= time.time() print("time cost for meshing: {}s".format(end_time - start_time))
Last edit: 4 years 5 months ago by gen.
