SymbolicBFI definedonelements = all elements that are needed for FreeDofs?
- creativeworker
- Senior Member
4 years 6 months ago - 4 years 6 months ago #3725
by creativeworker
SymbolicBFI definedonelements = all elements that are needed for FreeDofs? was created by creativeworker
I have a fes for the whole system. Using the definedon='regexpr' key the system is substructured into parts and stored to different fes_parts. Using the Compress method, I can use everything nice and clean for the different substructures.
To do the AssembleLinearization only on the elements in the substructure, I have a very large code-block to find all elements that have any dof in the substructure. Then translating the element-numbers into a BitArray that is then applied to the SymbolicBFI(..., definedonelements=BitArray).
Is there any shortcut available to find all elements related to the FreeDofs of such a fes_part automatically?
Also I didn't understand the difference in the following example (dealing with exactly that):
Kind regards,
fes_in = object.fespace(definedon=object.nonlinear_domain)
fesMini = Compress(fes_in)
u, v = fesMini.TnT()
print('---> Mini FE-Space', fesMini.ndof)
el_iterator = fesMini.Elements()
master_el_nrs = []
for el in el_iterator:
master_el_nrs.append(el.nr)
el_id = ElementId(VOL, el.nr)
act_el = BitArray(object.mesh.ne)
act_el[:] = False
for i in master_el_nrs:
act_el[i] = True
print('active elements...........', sum(act_el))
InternalMask = fes_in.FreeDofs()
wii = np.where(InternalMask)
ix_ii = np.ix_(wii[0],wii[0])
aMini = BilinearForm(fesMini)
aMini += SymbolicBFI(object.fcn_weak_K(object, material, u,v), definedonelements=act_el )
aMini.Assemble()
KiiMini = ngsolve2spmat_mat(aMini.mat)
#Ergebnis: Immer zu klein, mit und ohne definedonelements
fesfull = object.fespace()
ufull,vfull = fesfull.TnT()
aTest = BilinearForm(fesfull)
aTest +=SymbolicBFI(object.fcn_weak_K(object, material, ufull,vfull), definedonelements=act_el )
aTest.Assemble()
ATest = ngsolve2spmat_mat(aTest.mat)
KiiTest = ATest[ix_ii]
#Ergebnis: mit definedonelements ist das Ergebnis zu klein, ohne passt es.
#Die Anzahl der dofs sind immer gleich...
Kind regards,
Last edit: 4 years 6 months ago by creativeworker. Reason: Extension of the question with code
- creativeworker
- Senior Member
4 years 5 months ago - 4 years 5 months ago #3773
by creativeworker
Replied by creativeworker on topic SymbolicBFI definedonelements = all elements that are needed for FreeDofs?
Just wanted to give an update how I solved it meanwhile for me. Certainly not the most elegant way, but functional and not too slow:
def createInnerModel(object):
# get finite element space
fes = object.fespace()
fes_in = Compress(object.fespace(definedon=inner_domain))
# Suche alle dofs, die mit den inneren Elementen verknüpft sind
mastervertices = []
el_iterator = fes_in.Elements()
mastervertices.extend(fes.GetDofNrs(el_id))
dofs = BitArray(fes.ndof)
dofs[:] = False
for i in mastervertices:
dofs[i] = True
fesMini = Compress(fes, active_dofs=dofs)
# Search for all elements that are related to that dofs
master_el_nrs = []
for el in fes.Elements(VOL):
is_master = False
eldofs = fes.GetDofNrs(el_id)
for eldof in eldofs:
is_master |= eldof in mastervertices
if is_master:
E_tilde = np.unique(master_el_nrs)
act_el[:] = False
for i in E_tilde:
act_el[i] = True
return fesMini, act_el
Last edit: 4 years 5 months ago by creativeworker.
