specify intrules for 1d mesh
4 years 5 months ago #3709 by Jiashun
I am trying to generate the lumped mass matrix by setting integration rules.
For a 2d surface mesh in 3d, the following code works well.
ir = IntegrationRule(points = [(0,0), (1,0), (0,1)], weights = [1/6, 1/6, 1/6] ) ds_lumping = ds(intrules = { TRIG : ir })
However, for a 1d curved mesh in 2d, I guess it should be
ir = IntegrationRule(points = [(0,0), (1,0)], weights = [1/2, 1/2] ) ds_lumping = ds(intrules = { TRIG : ir })
However, it does not work.
Here is my code. I hope that the final result is a diagonal matrix.
import netgen.gui import netgen.meshing as ngm from ngsolve import * p = [[1,0,0],[1,1,0],[0,1,0],[0,0,0]] nr = len(p) mymesh= ngm.Mesh(dim=2) pids = [] for i in range(nr): pids.append (mymesh.Add (ngm.MeshPoint(ngm.Pnt(p[i])))) idx = mymesh.AddRegion("material", dim=1) for i in range(nr): if i<nr-1: mymesh.Add(ngm.Element1D([pids[i],pids[i+1]],index=idx)) else: mymesh.Add(ngm.Element1D([pids[i],pids[0]],index=idx)) mesh = Mesh(mymesh) fes = H1(mesh,order=1) u,v = fes.TnT() ir = IntegrationRule(points = [(0,0), (1,0)], weights = [1/2,1/2]) ds_lumping = ds(intrules = { TRIG : ir }, definedon=mesh.Boundaries("material")) a = BilinearForm(fes) a += u*v*ds_lumping a.Assemble() print(a.mat)
Thank you very much for your time in advance.
4 years 5 months ago #3713 by mneunteufel
Hi Jiashun,
for 1D Elements (in 2D) you need to specify the integration rule for segments, not for triangles. If you change the code to
ir = IntegrationRule(points = [(0,0), (1,0)], weights = [1/2,1/2]) ds_lumping = ds(intrules = { SEGM : ir }, definedon=mesh.Boundaries("material"))
then you should get a diagonal mass matrix.
4 years 5 months ago #3714 by Jiashun
It works! Thanks for your explanation.
