About the facet integral in the DG methods for solving the Stokes equation
4 years 7 months ago #3632
by Younghigh
To solve the Stokes equation, we use the DG methods. And the following formula is an important facet integral:
[tex]\sum_{F\in\mathcal F_h}\oint_F\left\{\nabla\bm{u}\right\}\bm{n}_F\cdot \left[\bm{v}\right]\mathrm{d}F.[/tex]
If coding in the NGSolve, I try this:
I cannot sure it is correct because I have no idea that the normal
is a column vector nor a row vector.
In addition, if one codes like
the corresponding matrix is
[tex]\left(
\begin{array}{cc}
a & c \\
b & d \\
\end{array}
\right),[/tex]
nor
[tex]\left(
\begin{array}{cc}
a & b \\
c & d \\
\end{array}
\right).[/tex]
Please help me, thank u.
Best wishes,
Di Yang
def outer(W,n):
return CoefficientFunction((W[0]*n[0], W[0]*n[1], W[1]*n[0], W[1]*n[1]), dims=(2,2))
def grad(a,b):
return CoefficientFunction((a.Diff(x), b.Diff(x), a.Diff(y), b.Diff(y)), dims=(2,2))
fes = L2(mesh, order=order_p, dim=2, dgjumps=True)
U, V = fes.TnT()
ux, uy = U
vx, vy = V
ux_other, uy_other = U.Other()
vx_other, vy_other = V.Other()
U_vec = CoefficientFunction((ux, uy))
U_Other = CoefficientFunction((ux_other, uy_other))
V_vec = CoefficientFunction((vx, vy))
V_Other = CoefficientFunction((vx_other, vy_other))
jump_U = U_vec - U_Other
jump_V = V_vec - V_Other
mean_gradU = 0.5*(grad(ux, uy) + grad(ux_other, uy_other))
mean_gradV = 0.5*(grad(vx, vy) + grad(vx_other, vy_other))
a += SymbolicBFI( InnerProduct( outer(jump_V, n), mean_gradU ),\
VOL, skeleton=True )
a += SymbolicBFI( InnerProduct( outer(V_vec, n), grad(ux,uy) ),\
BND, skeleton=True )
n=specialcf.normal(2)
CoefficientFunction((a,b,c,d), dims=(2,2))
[tex]\left(
\begin{array}{cc}
a & c \\
b & d \\
\end{array}
\right),[/tex]
nor
[tex]\left(
\begin{array}{cc}
a & b \\
c & d \\
\end{array}
\right).[/tex]
Best wishes,
Di Yang
4 years 7 months ago #3634
by hvwahl
Replied by hvwahl on topic About the facet integral in the DG methods for solving the Stokes equation
Hi Di Yang,
I think that the problem is that you're using the wrong FESpace. VectorL2 should be the one you need:
Best wishes,
Henry
V = VectorL2(mesh, order=3, dgjumps=True)
u, v = V.TnT()
jump_u = u - u.Other()
jump_v = v - v.Other()
mean_grad_u = 0.5 * (Grad(u) - Grad(u.Other()))
mean_grad_v = 0.5 * (Grad(v) - Grad(v.Other()))
a = BilinearForm(V)
a += InnerProduct(mean_grad_u * n, jump_v) * dx(skeleton=True)
a += InnerProduct(Grad(u) * n, v) * ds(skeleton=True)
Best wishes,
Henry
4 years 7 months ago #3638
by cwinters
Replied by cwinters on topic About the facet integral in the DG methods for solving the Stokes equation
Hi Di Yang,
concerning your question about coefficient functions, the input is taken row-wise. For
you can get out the components by
and I think evaluating (or drawing) the components is probably the quickest way to check the alignment.
Assume you have a mesh of the unit square, you could call
to get the output 2.
cf = CoefficientFunction((1,2,3,4), dims=(2,2))
cf[i,j]
cf[0,1](mesh(0.5,0.5))
Time to create page: 0.168 seconds
