Problem importing surface mesh using netgen
4 years 8 months ago #3569
by user85
Problem importing surface mesh using netgen was created by user85
Hello guys,
I want to import a surface mesh from an external source using the netgen gui.
As a first test, I loaded a step file with a simple geometry and exported both a volume mesh (object_neutral_format.mesh) and a surface mesh (object_surface_mesh_format.surf).
As a next step, I imported the volume mesh. This yields the expected result.
However, if I import the surface mesh, the object is deformed because the z coordinates are scaled with a factor 10 (see winmerge.png). Is this a bug or my fault?
Thank you for your help!
Max
Max
4 years 8 months ago #3570
by cwinters
Replied by cwinters on topic Problem importing surface mesh using netgen
Hi Max,
I think there was a fix regarding some scaling effects recently.
Since it works for me (version NGSolve-6.2.2101-17-g7fcf4d59d) I would suggest to check your version and update in case it is older than mine.
Hope that fixes your problem.
4 years 8 months ago #3574
by user85
Replied by user85 on topic Problem importing surface mesh using netgen
Hi Christoph,
you are absolutely right. Netgen works perfectly after installing the current version (NGSolve-6.2.2101-143-g1f064c8ac).
Thank you very much for your help!
Max
Max
Time to create page: 0.144 seconds
